    [Plugin] Solar/daylight analysis (v0.98, 2013-08-11)
    6 Posts 4 Posters 13.9k Views 4 Watching
      dfwlarch
      Daylight analysis using SketchUp has been more or less an interactive affair (turn on shadows, move the sliders, observe the light patterns), or it has required knowledge of external programs (Ecotect, Daysim, Radiance, etc.).
      This plugin calculates the amount of sunlight (insolation) falling on a group of faces over the course of a year, relative to the max sunlight theoretically available under a clear sky with no shade structures. The result is the daylight factor -- a number between 0.00 (completely shaded all year long) and 1.00 (nothing blocking the sun). The plugin color-codes and labels the target faces to indicate their daylight factor.
      http://farm6.staticflickr.com/5472/9454580305_811b64669e.jpg
      (model by Mugur)
      Basic mode:
      http://farm6.staticflickr.com/5525/9457367656_0f25afac4f.jpg
      Advanced mode:
      http://farm3.staticflickr.com/2828/9454585587_c68f956399.jpg
      Feature summary:
      • Sun positions are calculated for each hour, based on latitude and longitude
      • Calculates direct beam and diffuse irradiation (accounts for atmospheric scattering and ground-based reflectance)
      • Output can be written to a comma-separated file
      • Output can be in terms of solar irradiation (in watts per meter squared)
      • Shading structures selected by layer
      • Glass or semi-transparent faces selected by layer (user-input transmissivity)
        Future enhancements:
      • Ability to specify TMY3 weather file for solar insolation actually observed in v0.98
      • Optimize computation time
      Some code was translated from other people’s work. Please see credits, plugin options, and more details in the documentation (updated 2013-08-11)
      SimpleSolarStudy.pdf
      This is still ‘beta’, so please try it out and give me some bug/improvement feedback!
      v0.98 Updated 2013-08-11
      simple_solar_study_v098.rb
      .rb and help files (.html and .pdf)
      Test model
      • cottyC Offline
        cotty
        I've used the sample model and get the attached error.
        But a nice plugin idea!
        my SketchUp gallery
          'Brain
          This IS a good idea...
          BUT...
          Your code actually changes the native SketchUp Numeric class [ill-advised - although I realize you inherited it from someone else!***].
          The native Numeric class already has .radians and .degrees built in, to convert values 'to_deg' and 'to_rad' respectively.
          Please recode to avoid this mess...
          It is relatively straightforward to use Notepad++'s find/replace and then remove the unneeded class additions...
          Some tools are 'blacklisted' because of this kind of issue... including ***Gabriel Miller's Sunpositon.rb which is known to cause crashes with innocent tools like Fredo's CurviLoft !
          Also learn to use __FILE__ to get where the file is loading from [you already use it when setting up the menu].
          using the find_support_file method stops users from loading your plugin from their own custom-plugins folder...
          So...
          help_file = "Plugins/Simple_Solar_Study/help.html" hf = Sketchup.find_support_file "help.html", "Plugins/Simple_Solar_Study/" if {hf)...
          would be better if recast as:
          help_file = "../Simple_Solar_Study/help.html" hf = File.join(File.dirname(__FILE__), "Simple_Solar_Study", "help.html") if File.exist?(hf)...
          • KrisidiousK Offline
            Krisidious
            Can't wait to try it...
            By: Kristoff Rand
              dfwlarch
              Thanks for the feedback and for bearing with me. First SketchUp plugin (and first time coding in Ruby, for that matter! My background is C/C++, Perl and PHP).
              I've updated the original post with the new code.
                dfwlarch
                I posted a new version (see original post for files to download). Recent changes:
                ` %(#00BF00)[# Rev. | .Date..... | Notes
                0.98 | 2013-08-11 | Add ability to read weather data from TMY3 file
                .... | .......... | Bug: in fine/tmy3 mode, adjust for surface tilt
                .... | .......... | based on beam strength on horiz. surface, not to
                .... | .......... | normal-to-beam surface
                0.97 | 2013-08-07 | Bug: remove Numeric class overloads, make help
                .... | .......... | file search relative]`
                The enhancement in v0.98 lets you calculate the daylight factor as a ratio of observed weather to clear sky (Bird-Hulstrum model). So for example, this is the clear sky expectation over the course of a year for some geometry geolocated in Seattle, Washington (note the max daylight factor appearing in the bottom left corner area):
                http://farm8.staticflickr.com/7408/9489912899_8d30b0ac60.jpg
                Using a weather file from Seattle, the daylight factor looked like this:
                http://farm8.staticflickr.com/7370/9492664718_87f5fbc91c.jpg
                In other words, over a typical year the cloud cover allows only 78% of the theoretical maximum sunlight reaching a horizontal surface.
                Contrast that with the same geometry geolocated to Phoenix, Arizona. This is the daylight factor using the Phoenix TMY3 weather file. Very little cloud cover.
                http://farm8.staticflickr.com/7385/9492657232_c8a9a7ae59.jpg
                In TMY3 mode (a.k.a weather file), I could also have displayed the results in terms of watts per square meter, to get an idea of the amount of solar energy I could capture with a photovoltaic array. Note, however, that you would have to factor in PV efficiency (or inefficiency).
                It should also be noted that the computations currently take a while. The above test uses really simple geometry. Here is what is being calculated:
                • triangulated network of 96 faces to analyze
                • 27 faces make up the shading structure
                • analyzed from Jan 1 through Dec 31
                • run on a laptop with a core2 duo processor @2.26Ghz, 32 bit OS, 3GB ram
                  and it takes 126 secondsto crunch.
                Hence the need for this plugin:
                http://sketchucation.com/forums/viewtopic.php?f=323&t=53685.
                Profiling the code when it's trying to simulate a run of 15 days showed the following:
                  %   cumulative   self              self     total
                 time   seconds   seconds    calls  ms/call  ms/call  name
                 41.80   285.60    285.60   660648     0.43     0.60  BM_SimpleSolarStudy.inShadow
                 20.81   427.80    142.20    81464     1.75    23.65  Range#each
                  5.69   466.65     38.84  2404861     0.02     0.02  Array#[]
                  3.80   492.60     25.96    59682     0.43     0.78  BM_SimpleSolarStudy.adjustForTilt
                  1.89   505.49     12.88   660648     0.02     0.02  Geom.intersect_line_plane
                  1.81   517.84     12.36   660648     0.02     0.02  Sketchup;;Face#plane
                  1.70   529.47     11.63   660857     0.02     0.02  String#to_i
                  1.68   540.93     11.46   660648     0.02     0.02  Sketchup;;Face#classify_point
                  1.66   552.26     11.33   660648     0.02     0.02  Geom;;Point3d#-
                  1.63   563.41     11.15   661263     0.02     0.02  Hash#[]
                  1.62   574.51     11.10   662207     0.02     0.02  Fixnum#==
                  1.58   585.31     10.80   662137     0.02     0.02  Kernel.nil?
                  1.53   595.79     10.48   660853     0.02     0.02  Fixnum#&
                  1.51   606.14     10.35   661345     0.02     0.02  Fixnum#>
                  1.49   616.29     10.15   660648     0.02     0.02  Sketchup;;Drawingelement#hidden?
                  1.40   625.85      9.56   144037     0.07     0.10  Numeric#to_rad
                  0.98   632.53      6.68      203    32.89    32.89  Sketchup;;Drawingelement#material=
                  0.91   638.75      6.22   660851     0.01     0.01  Kernel.==
                  0.80   644.20      5.45   388599     0.01     0.01  Float#*
                  0.71   649.05      4.85    63402     0.08     0.10  Numeric#to_deg
                  0.62   653.26      4.22   119364     0.04     0.05  Geom;;Vector3d#new
                  0.61   657.43      4.16      744     5.60    13.40  BM_SimpleSolarStudy;;SSS_sunData#calcSun
