    Rhino question
    4 Posts 2 Posters 518 Views 2 Watching
    • arail1A Offline
      arail1
      Is there a way to change the default front and back face colors? When I export a file out of Rhino as a skp the file in SketchUp has beige for the front face color instead of white. All of the front faces are beige and any new geometry I create in the model is also beige. And I hate beige!
      Thanks for any advice you've got. I have asked the same question on the Rhino forum.
      • arail1A Offline
        arail1
        I asked the same question on the Rhino forum and Jeff Hammond, helpful as always, pointed out that opening a 2nd, empty version of SketchUp and dragging and dropping the Rhino export into it will result in the Rhino export adopting all the settings of the SketchUp file.
        Problem solved.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          You can also change the default material color in the "styles" window.
          • arail1A Offline
            arail1
            Thanks for the reminder. That tip will also come in useful going back and forth between the two programs.
