    Little Nelly Gyrocopter
    11 Posts 10 Posters 964 Views 10 Watching
    • cheddaC Offline
      chedda
      Many thanks to John (jpalm23) for the link to the airfield HDR. The model i found along time ago deep within the internet. It took some work getting the textures projected and adjusted. C&C welcome as always sketchup & maxwell render.
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
      • tademaT Offline
        tadema
        She's a beauty! πŸ‘
        John
        • pbacotP Offline
          Sweet. And what fun is a little get-about like this without a full weapons array?
          • olisheaO Offline
            olishea
            awesome!! πŸ˜„
            oli
            • BoxB Offline
              Excellent as always.
              My only comment would be, a bit of droop on your blades would add to the realism.
              I agree the weapons array is vital when it comes to traffic congestion and parking.
              • allanxA Offline
                allanx
                Very nice composition Simon...Great use of Maxwell Render.
                allanx
                Portfolio
                • hellnbakH Offline
                  hellnbak
                  Very nice. All you need now is Mel Gibson sitting in the cockpit πŸ˜†
                  A couple of observations --
                  I know it's an overcast day, but even given that the shadows under the copter seem a bit weak.
                  And it seems to be sitting on top of the grass.
                  • Bryan KB Offline
                    You only live twice!
                    Well done!
                      jpalm32
                      Very nice. More with a real plane please.
                      • CarlohC Offline
                        Carloh
                        If you want some harder shadows when you work with a HDRI environment i lately imported a simple sphere inside maxwell studio moved it to a height where it can simulate the sun and set a very strong emitter to it. Although it produces some fireflies when the emitter is set too strong you can adjust it nicely with Multilight.
                        nevertheless nice rendering once again! πŸ‘
                        • cheddaC Offline
                          chedda
                          Thanks for all the comments guys. I'm not sure about the shadow i think it's ok. The rotors should be a little curved and sag your right. Regarding floating on the grass that's a tricky one perhaps i should have added a few grass blades in photoshop in front of the wheels to complete the illusion. Carloh using a sphere may not be the most efficient way as more polygons means more time. I'd suggest a simple plane instead although it'll still add to time.HDR is the quickest solution IMHO and gives the correct lighting.It also means i can easily achieve SL20+ @4mpx in a couple of hours cooking. In this case the illumination intensity is double that of the other channels as it didn't pop enough. I'm still on the look out for aerial hdr maps if anyone has any leads.
