    Using chunkyPng library with Sketchup
    3 Posts 3 Posters 903 Views 3 Watching
      LFloissac
      I need to write a PNG image processed into a Sketchup plugin.
      Note: this image is not a screen copy of Sketchup scene but a process result. So, the SU usual PNG save image method is not suitable for that.
      This is ChunkyPNG library job !
      see http://rubydoc.info/gems/chunky_png/frames
      1. When I launch a simple test program directly from ruby 1.8.6, Its working well.
      2. The same code, with the same path lauched from SU (ruby console) crashs (see above).
      3. I've find a "dirty" solution by creating new Set and SortedSet classes (here attached).
      4. Does someone have a better solution ?
      The problem seems to come from the "set" ruby command who could be overided in the SU ruby engine.
      1. The code of a simple test case:
        $LOAD_PATH.unshift(File.dirname(FILE))
        $LOAD_PATH.unshift File.join(File.dirname(FILE), 'lib')
        $LOAD_PATH.unshift File.join(File.dirname(FILE), 'lib', 'chunky_png')
      require 'chunky_png'
      Creating an image from scratch, save as an interlaced PNG
      png = ChunkyPNG::Image.new(201, 201, ChunkyPNG::Color::TRANSPARENT)
      for y in 0..200
      for x in 1..200
      png[x,y] = ChunkyPNG::Color.rgba(x, y, 0, 255)
      png.save('c:/TMP/testChunky_pngFile.png', :interlace => true)
      puts "Image saved"
      2a. The first error message is :
      load "C:/TMP/PNG_TEST/pngTest.rb"
      $LOAD_PATH: C:/TMP/PNG_TEST/lib/chunky_pngC:/TMP/PNG_TEST/libC:/TMP/PNG_TESTC:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ProgressBar/squall/classC:/Program Files (x86)/Google/Google SketchUp 8/PluginsC:/Program Files (x86)/Google/Google SketchUp 8/PluginsC:/Program Files (x86)/Google/Google SketchUp 8/Tools
      Error: #<LoadError: C:/TMP/PNG_TEST/lib/chunky_png/chunky_png.rb:2:in require': no such file to load -- set> C:/TMP/PNG_TEST/pngTest.rb:7 C:/TMP/PNG_TEST/lib/chunky_png/chunky_png.rb:2 C:/TMP/PNG_TEST/pngTest.rb:7:in require'
      (eval):55:in `load'
      (eval):55
      2a. If I add the "standard ruby" set.rb class into the path a second eror message appears
      $LOAD_PATH: C:/TMP/PNG_TEST/lib/chunky_pngC:/TMP/PNG_TEST/libC:/TMP/PNG_TESTC:/TMP/PNG_TEST/lib/chunky_pngC:/TMP/PNG_TEST/libC:/TMP/PNG_TESTC:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ProgressBar/squall/classC:/Program Files (x86)/Google/Google SketchUp 8/PluginsC:/Program Files (x86)/Google/Google SketchUp 8/PluginsC:/Program Files (x86)/Google/Google SketchUp 8/Tools
      Error: #<NoMethodError: undefined method best_color_settings' for #<Set: {4278190335, 0, 16711935, 64255}>> C:/TMP/PNG_TEST/lib/chunky_png/canvas/png_encoding.rb:125 C:/TMP/PNG_TEST/lib/chunky_png/canvas/png_encoding.rb:75:in to_datastream'
      C:/TMP/PNG_TEST/lib/chunky_png/image.rb:62:in to_datastream' C:/TMP/PNG_TEST/lib/chunky_png/canvas/png_encoding.rb:35:in write'
      C:/TMP/PNG_TEST/lib/chunky_png/canvas/png_encoding.rb:43:in save' C:/TMP/PNG_TEST/lib/chunky_png/canvas/png_encoding.rb:43:in open'
      C:/TMP/PNG_TEST/lib/chunky_png/canvas/png_encoding.rb:43:in save' C:/TMP/PNG_TEST/pngTest.rb:30 (eval):7:in load'
      (eval):7
      1. The following "dirty patch" (here attached) works well:
        a. Duplicate "set.rb" file from "standard ruby 1.8.6". Rename it "set_bis.rb"
        b. In this new file "set_bis", rename classes "Set" and "SortedSet" into "Set_bis" and "SortedSet_bis"
        c. Change require 'Set' to require 'Set_bis' into chunky_png.rb
        d. Rename "Set" and "SortedSet" calls into "Palette.rb". These calls became "Set_bis" and "SortedSet_bis"
      Note: The following ressources also need to be in the load path.
      • enumerator.so
      • stringio.so
      • zlib.so
      • bibliothèque zlib
      chunkyPng_bis.zip
      • renderizaR Offline
        renderiza
        Can a Moderator place this on the Developers forum so it has better chance to get a reply?
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • massimoM Offline
          massimo Moderator
          Done.
