    Gentle stone carving technique
    5 Posts 2 Posters 1.1k Views 2 Watching
    • tibetT
      tibet
      hi,
      i ´d like to ask, is there any other, more gentle technique to do stone carving in SU,
      rather than use solid tools please?
      thanks!
      stone_carving.skp
      SU 2015 Pro on Win10 x64
        What do you mean by "gentle"? Could you show an example?
        • tibetT
          tibet
          hi,
          by "gentle" i mean to make the same depth of carving everywhere ( to copy a surface with
          carving ), because the rock is not flat.
          thanks
          http://img.sceper.eu/images/qBiFx.jpg
            Oh! I see.
            Make a copy of the surface of the stone. You don't need all of it, just the part surrounding the letters and use Joint Push/Pull to push in the surface to the desired depth of your letters. Make the shape a closed solid and use that surface to trim the letters the letters. The set the letters into the stone by the desired depth and Solid tools as you did before. Due to the intersection of all the complex geometry in your letters be ready for the creation of small gaps. Perhaps scale everything up to a very large size before the intersections are done.
            • tibetT
              tibet
              thanks for your helpful answer,i´m sure this technique will works!
