    Model Axis vs Component Axis
    8 Posts 4 Posters 792 Views 4 Watching
    • Z Offline
      Zollus
      Regarding Sketchup Inferencing:
      While using various tools like the move tool or the line tool, you can have it snap to the red, green or blue directions of the model axis. You can even lock to those directions with the arrow keys on the keyboard.
      (You can check out the help documentation on inferencing to be clear on what I am referring to: http://support.google.com/sketchup/bin/answer.py?hl=en&answer=70143)
      In Sketchup 7, while editing a component, this Axis Inferencing would continue to lock to the model's axis (some people refer to it as "global axis") regardless to the orientation of your component's axis.
      But in Sketchup 8, when editing a component, it inferences to the component's axis instead.
      If you have your axis visible (via the "View > Axes" menu), you can even see the model axis move to the component's axis location while editing that component.
      The only documentation I have found related to this change is located at the "What's changed in this release of Sketchup" page located at http://support.google.com/sketchup/bin/answer.py?hl=en&answer=115424
      It says:
      Sketch axes
      The axes can now (optionally) be aligned with component axes while editing a component.
      I am at a company that is trying to transition from Sketchup 7 to Sketchup 8, and this change is really messing up my engineers and holding us back from making the transition.
      I would like to turn this feature off, and go back to the Sketchup 7 style. The fact that they listed this as optional gives me hope that this can be done. Does anyone know where this setting is located?
      I have looked through the Preferences screen, the Model Info screen and the Styles screen and was unable to find anything that seemed related to this setting.
      Any help would be appreciated.
      -Thanks!
      • mitcorbM Offline
        mitcorb
        Hi.
        One method may be to select the component, explode, then immediately remake it while it is still selected and in its current orientation. However, if this is a repetitive element and you need all of the other instances to retain their current axial orientation, you would maybe make this one instance unique, then explode, then remake component.
        Did I understand your question?
        • mitcorbM Offline
          mitcorb
          Hi, Zollus:
          As a followup, I thought I would mention that if you right click on a component, in the context menu, you can set the component axes to another orientation.
          Does this help any?
          Some engineering disciplines prefer a different Global Axis orientation for modeling than the Sketchup standard. Is this the case for your company?
          • Z Offline
            Zollus
            Thanks, but the explode and remake isn't going to work very well, we have a few thousand parts (each a component) in a model, and the the part's axis is important when we're generating the code for our CNC mills to make the parts. And a few parts are used multiple times in different orientations (one component definition with multiple component instances) so one instance would win, while the others would seem to be in wacky directions.
            Primarily its the behavior of the move tool and how it locks on to certain directions. (technically it affects some of the other tools like the line tool, but we use the move tool much more often). I guess I could write my own move tool, but I was hoping that it wouldn't come to that and I'd be able to find some "Inferencing Options" screen with a checkbox for "Lock on to Component Axis" that I could uncheck so that it would revert to locking on to the model axis.
              It doesn't sound like this is a Move tool issue per se. This sounds like a good application for gluing attributes for the components. When creating the component, locate the origin at a point on/in the component that you'll use to locate the part in the model and set Gluing to Any.
              I do this for hardware I need to add to models. For a bolt or screw I locate the component origin at the base or top of the head depending on the screw so I can quickly place it relative to the surface It goes into. You can see how easily the components can then be place in this video.
              Unfortunately if you've already made a pile of components, you'll need to modify them but if you use the correct work flow going forward, you should find it's a big help.
              • Jean-FrancoJ Offline
                Jean-Franco
                Hi Dave,
                what kind of plugin do you use at the end of the video ?
                Jean-Franco
                  @jean-franco said:
                  Hi Dave,
                  Hi Jean-Franco, do you mean for the counterbored holes? That's part of the Wudworx toolset. See this link.
                    Jean-Franco
                    Yes exactly, thanks for the link.
                    Jean-Franco
