    Trouble with DC's
    3 Posts 2 Posters 975 Views 2 Watching
    • royalcasaR Offline
      royalcasa
      I use sketchup in interior design and spend most of the time building kitchens, work is a daily procedure which I hardly change lately, but I spend that much time importing and looking trough libraries to get the components...
      I decided to get into DC's so that I'll work on that one dynamic component until it fills my needs...
      I'd need some expert advice though, the 'children' that I resize get their position scaled too, and I could not figure out how to keep them in the exact XYZ...
      any help ?
      I'll attach the DC, I know whoever is gonna help is going to ask that
      ps: I work with Italian, so terms and labels are not English
      base.skp
      • P Offline
        pcmoor
        Hi Gert-Jan
        My method is to place the groups in the desired locations, then right click each one and change the axis so that I can locate a common point. Then figure out the formulas, copy the common ones through.
        I updated your component to suit, also added variables to cover the width and height without directly exposing lenY, lenZ this avoids the blanks between option changes.
        Cheers
        Philip
        base2.skp
        • P Offline
          pcmoor
          added door division for longer cabinets, dynamic openings...swing on side only.. try mirror door as part of visible/invisible maybe solution?
          added some dynamic attributes
