    [Plugin] s4u_toComponents
    89 Posts 26 Posters 109.5k Views 26 Watching
    • N
      numerobis
      Thanks!
      And what about the other question? Not possible? Or do i need to use a different tool instead of "Faces to Components"?
      • hdpvH
        hdpv
        Not possible for all object.Unless you divide faces to triangle
        You need use a diferrent tool.
        Suforyou
        http://www.sketchupforyou.com
        • hdpvH
          hdpv
          Hi Numerobis!
          The same components if face is rectangle or parallelogram.
          about trapezium ,the same components if face is uniform.
          about triangle ,all the same components.
          Version 5.1.0 is some bug,I fixed it in curent version v5.2.1 .
          Suforyou
          • N
            numerobis
            Ok, thanks for clarifying this.
            So what different tool would this be?
              French UI πŸ˜‰
              Very cool for fractal volumes in 3 seconds! 😎
              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9562508_orig.gif
              fr.zip
              • hdpvH
                hdpv
                Merci Pilou! πŸ˜„
                Suforyou
                • R
                  reza1813
                  Dear Huynh Duong Phuong Vi,
                  Hello, I kindly reach you to inform you about a problem when I am using S4U to Components v6.2.0.
                  Actually, I firstly select half of triangular for this kind of curve surface with S4U Select v2.1.1 plugin and then select the component in order to put on the surface with exact shape and direction But in some part, the component doesn't fit properly or Comes out of the surface.
                  Would you mind any possibility to fix this problem for the next update of S4U to Components in order to deal with this kind approach?
                  S4U to Components
                  s4u to Components
                  Sincerely,
                  Hamidreza
                  • L
                    lianproiemti
                    is there a way that i can get the earlier versions of s4u plugins?
                    • hdpvH
                      hdpv
                      Sorry,I don't support for the earlier versions.
                      Suforyou
                      • 5 / 5
