    [Plugin] s4u_toComponents
    89 Posts 26 Posters 102.4k Views 26 Watching
    • N Offline
      numerobis
      So is ist not possible to get a a result with instanced components over the whole object?
      Btw. how long does the trial period goes? I couldn't find any info about it.
      • hdpvH Offline
        hdpv
        Trial Period: 15 days
        http://extensions.sketchup.com/en/content/s4u-components
        Suforyou
        http://www.sketchupforyou.com
        • N Offline
          numerobis
          And what about the other question? Not possible? Or do i need to use a different tool instead of "Faces to Components"?
          • hdpvH Offline
            hdpv
            Not possible for all object.Unless you divide faces to triangle
            You need use a diferrent tool.
            Suforyou
            • hdpvH Offline
              hdpv
              Hi Numerobis!
              The same components if face is rectangle or parallelogram.
              about trapezium ,the same components if face is uniform.
              about triangle ,all the same components.
              Version 5.1.0 is some bug,I fixed it in curent version v5.2.1 .
              Suforyou
              • N Offline
                numerobis
                Ok, thanks for clarifying this.
                So what different tool would this be?
                  French UI πŸ˜‰
                  Very cool for fractal volumes in 3 seconds! 😎
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9562508_orig.gif
                  fr.zip
                  • hdpvH Offline
                    hdpv
                    Merci Pilou! πŸ˜„
                    Suforyou
                      reza1813
                      Dear Huynh Duong Phuong Vi,
                      Hello, I kindly reach you to inform you about a problem when I am using S4U to Components v6.2.0.
                      Actually, I firstly select half of triangular for this kind of curve surface with S4U Select v2.1.1 plugin and then select the component in order to put on the surface with exact shape and direction But in some part, the component doesn't fit properly or Comes out of the surface.
                      Would you mind any possibility to fix this problem for the next update of S4U to Components in order to deal with this kind approach?
                      S4U to Components
                      s4u to Components
                      Sincerely,
                      Hamidreza
                        lianproiemti
                        is there a way that i can get the earlier versions of s4u plugins?
                        • hdpvH Offline
                          hdpv
                          Sorry,I don't support for the earlier versions.
                          Suforyou
                          • 5 / 5
