    [Plugin] s4u_toComponents
    89 Posts 26 Posters 103.5k Views 26 Watching
      g.moggel
      you know what would be awesome?
      to be able to fit a component onto a face depending on the textures orientation on that face.
      i try to optimize some tree models and they have the leaf texture aplied. the leaves are a flat plane though. i would like to fit a component with more complex geometry on it that would replace the leaves with actual geometry. problem is if i use your plugin the orientation is totaly different on each plane. would it be possible to use the texture coordinates to arrange a component on it? the texture would need to be somewhat the same size.
      see all the images attached. i marked where the leaf stem would need to go.
      this would be so useful to me and i'm sure some other archviz guys.
      cheers and thanks for your hard work. i already have your slice plugin and its amazing!
      cheers,
      mo
      • hdpvH Offline
        hdpv
        Hi Mo!
        I understand you, I will try to do.
        Suforyou
        http://www.sketchupforyou.com
        • hdpvH Offline
          hdpv
          I have been updated:
          • Make faces to Components follow origin face's texture
          • Replace Components by selected component.
            http://extensions.sketchup.com/en/content/s4u-components
          Suforyou
            Allways so cool! 😎
            Apply twice on a simple box! πŸ˜„
            • N Offline
              numerobis
              I have installed the trial version of this nice plugin and i have a weird problem - i'm not sure if i'm doing something wrong or if it is a bug...?!?
              I can't get it to replace all faces with instances (using "Faces to Components"), only the panels that are selected in the screenshot are the same components, all the other panels become unique components... πŸ˜•
              http://i57.tinypic.com/34e2u6x.jpg
              And it's always the same shape of panels.
              Is this a bug or a feature?
              • N Offline
                numerobis
                So is ist not possible to get a a result with instanced components over the whole object?
                Btw. how long does the trial period goes? I couldn't find any info about it.
                • hdpvH Offline
                  hdpv
                  Trial Period: 15 days
                  Suforyou
                  • N Offline
                    numerobis
                    And what about the other question? Not possible? Or do i need to use a different tool instead of "Faces to Components"?
                    • hdpvH Offline
                      hdpv
                      Not possible for all object.Unless you divide faces to triangle
                      You need use a diferrent tool.
                      Suforyou
                      • hdpvH Offline
                        hdpv
                        Hi Numerobis!
                        The same components if face is rectangle or parallelogram.
                        about trapezium ,the same components if face is uniform.
                        about triangle ,all the same components.
                        Version 5.1.0 is some bug,I fixed it in curent version v5.2.1 .
                        Suforyou
                        • N Offline
                          numerobis
                          Ok, thanks for clarifying this.
                          So what different tool would this be?
                            French UI πŸ˜‰
                            Very cool for fractal volumes in 3 seconds! 😎
                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9562508_orig.gif
                            fr.zip
                            • hdpvH Offline
                              hdpv
                              Merci Pilou! πŸ˜„
                              Suforyou
                                reza1813
                                Dear Huynh Duong Phuong Vi,
                                Hello, I kindly reach you to inform you about a problem when I am using S4U to Components v6.2.0.
                                Actually, I firstly select half of triangular for this kind of curve surface with S4U Select v2.1.1 plugin and then select the component in order to put on the surface with exact shape and direction But in some part, the component doesn't fit properly or Comes out of the surface.
                                Would you mind any possibility to fix this problem for the next update of S4U to Components in order to deal with this kind approach?
                                S4U to Components
                                s4u to Components
                                Sincerely,
                                Hamidreza
                                  lianproiemti
                                  is there a way that i can get the earlier versions of s4u plugins?
                                  • hdpvH Offline
                                    hdpv
                                    Sorry,I don't support for the earlier versions.
                                    Suforyou
                                    • 5 / 5
