    Scene Rename not working
    4 Posts 3 Posters 1.2k Views 3 Watching
    • bagateloB Offline
      bagatelo
      Why Scene Rename is not working? Someone can help me?
      My SU is 8.
      My Windows is seven 64bits.
      http://www.smustard.com/script/SceneRename
      • G Offline
        glro
        My SU is 8.
        no
        without more explanations, it seems difficult to help...
        you could open the ruby console and copy here the error message, if any
        or
        use this plugin instead
        http://sketchucation.com/forums/viewtopic.php?t=41787
        give a name to the scene BEFORE it is created, so you don't have to rename it...
        • bagateloB Offline
          bagatelo
          The problem is with Artisan. So, because I don't use artisan, I put them off.
          • renderizaR Offline
            renderiza
            Hi, not familiar with the plugin you mentioned but you might want to check [Re]Scene which also is capable of renaming all your scenes.
            http://sketchucation.com/forums/viewtopic.php?p=472206#p472206
            Cheers!
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
