    Camera trouble
    6 Posts 2 Posters 573 Views 2 Watching
    • GennDALFG
      GennDALF
      Hi all!
      Glad to meet with community!
      Short preamble:
      My 3D-modeling experience isn't wide: about 7 years ago I've discovered about 3Ds Max and learned to work in it about few years, but that's not mine in general - 'cause I'm good-for-nothing artist. But as a result I still got some skills.
      So, for now I'm modeling my future record studio. I decided to work in SketchUp for time saving.
      The output from this model I want to use as an illustration material for few exhibitions.
      Now, the subject:
      While modeling all was fine. Then I started to place cameras for locked views. First 4 cameras have been placed as it should be. Troubles began with a 5th camera - I saw this:
      5th camera - what is this?
      After all attempts to make it normal I noticed that the view on first camera also changed from this:View 1, as it should be
      to this:View 1, smth strange
      I concede, that I could "press a wrong key", but even through I don't know how to make it normal.
      That's why I need your help.
      And how it usually happens I'm pressed for time... 😒 So, I hope somebody can explain me what's going on with my model and say where I need to dig up.
      Thanks!
      • mitcorbM
        mitcorb
        This is a thread with similar issue and if you read down a bit there are other links in some of the replies.
        404 Not Found
        (sketchucation.com)
        • GennDALFG
          GennDALF
          Thanks!
          After lot of jumps through links I've found the solution - to set the normal scenes and delete cameras itself and ACT scenes.
          So, for my case it's even better to operate just scenes, without cameras.
          • mitcorbM
            mitcorb
            Hi Gennadiy:
            I am glad you replied. I don't know if the developers' intention for the ACT process is to delete the cameras and save the scenes only, but it seems the only way to stop the clipping effect.
            • GennDALFG
              GennDALF
              Perhaps developers intend only 1-2 cameras, using without intersecting its FOV volumes. And if you want to set the foreshortening you use scenes. Who knows..)
              Few years ago I've worked with Torque3D game engine (TorqueGameEngine - TGE in past). The point I want emphasize - their forum is common for the developers of engine itself and the developers who are working with it. So you can ask a question directly to a person who wrote blocks of code you are interested in! As far as I know it's not widely-spread policy, but when we are speaking about rather complex products as 3D-renders, different engines and so on - it is sometimes invaluable.
              • mitcorbM
                mitcorb
                Sketchup Development Team monitors this Forum. When they feel it important to reply they will. Just not quite as often as we might wish. 😄
