    Save as SKETCHUP 2013 problem
    7 Posts 4 Posters 755 Views 4 Watching
      carlocki
      everytime a just save a model with my SU pro i cannot upload it on 3dsmax
      I tested the same installation (last download) on another windows 7 pc and the results is the same.
      If i save on SU8 the import is ok.
      someone can help me with this bug?
      • FrederikF Offline
        Frederik
        Although I'm not a 3dsmax user, I'd assume it's because the 3dsmax importer needs to be updated to be compatible with SU 2013...
        Until a new update is ready, I suggest that you save as SU 8 model from SU 2013...
        Cheers
        Kim Frederik
          carlocki
          i teste it with different max (2013 2014) in different pc's. Same damn error importing. save on SU8 from the same SU2013 i have no problem.
          is my pc's and my max and my su togheter...cannot find the problem
            Then save your SketchUp model in SketchUp 8 format. There is a dropdown list when you do Save As.
              carlocki
              is a 2kb loss this make everything go bad.
              2kilingbite
                Sorry but you lost me now. What do you mean?
                What goes bad? what 2kb loss? "2killingbite"?
                • Chris FullmerC Offline
                  Hi Carlo, Kim had it correct. 3dsmax needs to update their importers to read the SU 2013 file format. You can contact them directly to find out what their timeframe is for making that update. Thanks,
                  Chris
                  All my Plugins I've written
