    Shadow Control Possible? (solved)
    10 Posts 3 Posters 6.5k Views 3 Watching
    • renderizaR
      renderiza
      I want to create a plugin that will set scenes with different rendering styles so I can then export them to Photoshop.
      To get better idea of what I want to create through code please open this LINK to see the rendering setting to set scenes for Color, Shadows, Alpha Channel and ZDeapth.
      I can't seem to find a way to control Shadows parameter like 'Light' and 'Dark' values. Also the only way to active Shadows through code that I know of is this the following...
      Sketchup.send_action(1213)
      I am just starting this so I don't have much but here is a WIP to creat aplha channel (still not complete).
      ###Alpha Channe###
      Sketchup.active_model.rendering_options['DisplayFog']=false
      Sketchup.active_model.rendering_options['BackgroundColor']=[0, 0, 0]
      #Ground
      Sketchup.active_model.rendering_options['DrawGround']=false
      #Sky
      Sketchup.active_model.rendering_options['DrawHorizon']=false
      #EndPoint (lines)
      Sketchup.active_model.rendering_options['DrawLineEnds']=false
      #Profile (lines)
      Sketchup.active_model.rendering_options['DrawSilhouettes']=false
      #Display Lines?
      Sketchup.active_model.rendering_options['EdgeDisplayMode']=0
      #Back Face Color
      Sketchup.active_model.rendering_options['FaceBackColor']=[255, 255, 255]
      #Front Face Color
      Sketchup.active_model.rendering_options['FaceFrontColor']=[255, 255, 255]
      #Fog Color
      Sketchup.active_model.rendering_options['FogColor']=[255, 255, 255]
      If anyone can help me I will be very greatfull. Thanks!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • TIGT
        You also need to consider the shadow_info and its ['Light'] & ['Dark'] settings [%] ?
        • renderizaR
          renderiza
          For example if I want to set the Alpha Channel scene I need to set the following shadow settings with code...
          Shadow Settings:
          Use Shadow = false
          Light = 0
          Dark = 100
          Use sun for shading = true
          If I am not mistaken the shadow_info Api is only to extract their values so it cannot let me set their values right?
          Maybe the solution is to provide SketchUp File with all the scenes with styles settings already provided and just import the them somehow but not sure if that is possible. I need to do some more research! πŸ€“
          • TIGT
            No. πŸ˜’
            Play around in the Ruby Console to see what changing things does...
            Sketchup.active_model.shadow_info['Dark']=0 Sketchup.active_model.shadow_info['Light']=100
            Will both change things as you might expect πŸ˜•
            • renderizaR
              renderiza
              WOW!
              TIG, did I said you are awesome! 😍
              Thanks!
              • renderizaR
                renderiza
                The following is the code for creating an Alpha Channel Scene...
                ###Alpha Channe###
                ###Create Scene###
                Sketchup.send_action(CMD_PAGE_NEW)
                ###Style###
                Sketchup.active_model.rendering_options['RenderMode']=5
                #Edge Settings
                #Face Settings
                #Background Settings
                #Watermark Settings
                Sketchup.active_model.rendering_options['DisplayWatermarks']=false
                ###Shadow Settings###
                Sketchup.active_model.shadow_info['DisplayShadows']=false
                Sketchup.active_model.shadow_info['UseSunForAllShading']=true
                Sketchup.active_model.shadow_info['Light']=0
                Sketchup.active_model.shadow_info['Dark']=100
                ###Fog Settings###
                ###Update###
                model = Sketchup.active_model
                pages = model.pages
                c_page = pages.selected_page
                c_page.update
                Only thing I wish didn't happen is the Warning! message saying "You are creating or updating a scene and have not saved the changes you've made to your style."
                Is there a way to get rid of that?
                Anyways just wanted to post what I had so far...thanks!
                • renderizaR
                  renderiza
                  Here is an interesting plugin...
                  Rendering Favourites (v1.1) by Trogluddite - This is a plugin which can store style options and its great to store things like Alpha Channels, ZDeapth, Color, ect.
                  • renderizaR
                    renderiza
                    Here is what I assume to be a BUG... When the code creates the Zdepth page even though the Fog settings appear to be applied it doesn't display it! This is strange and for it to work I need to move the distance slider a nudge manually which defeats the purpose. πŸ˜•
                    Here is the code...Notice I saved the style properties into folder and I am just importing them so the rest of the code works on Shadow & Fog properties.
                    pages = model.pages
                    ###Aplha################################
                    ###Fog Settings###
                    pages.add("Aplha")
                    styles = Sketchup.active_model.styles
                    status = styles.add_style "c;\\styles\\Aplha Style.style", true
                    selpage = pages.selected_page
                    selpage.update
                    ###Zdepth###############################
                    ###Fog Settings###
                    Sketchup.active_model.rendering_options["FogEndDist"]=35.m
                    Sketchup.active_model.rendering_options['DisplayFog']=true
                    pages.add("Zdepth")
                    status = styles.add_style "c;\\styles\\Zdepth Style.style", true
                    selpage.update
                    Any help will be appreciated! πŸ‘
                    • renderizaR
                      renderiza
                      Seems the Fog part is working now but not sure what was that I did to fix it. For the most part I think I am finish but just need to worry about the interface part of things now.
                      pages = model.pages
                      ###Alpha################################
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Alpha")
                      status = styles.add_style "c;\\styles\\Alpha Style.style", true
                      ###Update###
                      selpage.update
                      ###Cley#################################
                      Sketchup.active_model.shadow_info['Light']=50
                      Sketchup.active_model.shadow_info['Dark']=15
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Cley")
                      status = styles.add_style "c;\\styles\\Cley Style.style", true
                      ###Update###
                      selpage.update
                      ###Color################################
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Color")
                      status = styles.add_style "c;\\styles\\Color Style.style", true
                      ###Update###
                      selpage.update
                      ###Color by Layer#######################
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Color by Layer")
                      status = styles.add_style "c;\\styles\\Color by Layer Style.style", true
                      ###Update###
                      selpage.update
                      ###Line################################
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Line")
                      status = styles.add_style "c;\\styles\\Line Style.style", true
                      ###Update###
                      selpage.update
                      ###Profile##############################
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Profile")
                      status = styles.add_style "c;\\styles\\Profile Style.style", true
                      ###Update###
                      selpage.update
                      ###Shadow################################
                      Sketchup.active_model.shadow_info['DisplayShadows']=true
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Shadow")
                      status = styles.add_style "c;\\styles\\Shadow Style.style", true
                      ###Update###
                      selpage.update
                      ###Texture################################
                      ###Fog Settings###
                      ###Add Page###
                      pages.add("Texture")
                      status = styles.add_style "c;\\styles\\Texture Style.style", true
                      ###Update###
                      selpage.update
                      ###Fog Settings###
                      Sketchup.active_model.rendering_options['FogEndDist']=35.m
                      ###Add Page###
                      pages.add("Zdepth")
                      ###Update###
                      selpage.update
                      • M
                        mrsailboat83
                        dude, did you know that everytime you save a scene there is the option to save it with the current settings? Maybe this wasn't the case back in 2013 but there you go
