    LO 2013 dimensioningstyle bug, wrong unit
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    9 Posts 5 Posters 9.0k Views 5 Watching
    • atelierpaarA Offline
      atelierpaar
      LO 2013 dimensioningstyle bug:
      Style Selection: "metric (or decimal in German)"
      Unit "m"
      Resulting unit-format in LO 2013 = " (inch) instead of m (meter) 😮
      thanks for looking into it
      Uli
      • KrisidiousK Offline
        Krisidious
        There is decimal inches and there are decimal meters, millimeters etc. you must select decimal then the type of unit. to the right side of the menu.
        By: Kristoff Rand
          atelierpaar
          I`am sorry for explaining the problem poorly -
          I attach a screenshot - I did select "decimal" as well as "unit -m-"
          still Lo replies with "(= inch )
          any Idea?
          130621 SO Bug 1.pdf
            Did you place the dimension before setting the units? LO won't automatically revise dimensions already placed but if you select the Dimension tool and change the units, the subsequent dimensions should show in the correct units. In the attached example I placed the top dimension first with units set in inches. The next one with it set to mm and finally the bottom one with units set to meters.
            You can change the units of the dimensions by selecting them and changing the Units in the Dimension inspector or by sampling a correct dimension with the eyedropper and painting that sample on the other dimensions.
            dims example.pdf
              mwm5053
              You probably know this but after you select dimension tool you then set type of dimensions to decimal/ mm, cm or m.Seems to work fine.
              LO test dim. metric.layout
              2011 iMac
              SU 2015 Pro, 2017 Make
              V2 Twilight
              macOS Sierra 10.12.5
                Krisidious
                This must be a German version issue... I'm not seeing it with mine.
                By: Kristoff Rand
                  atelierpaar
                  Hello again ,and thanks for your fast response.
                  I forgot to mention, I am working on the German Version of LO.
                  The Dimensions "mm" and "cm" work fine 😄 .
                  Only if I select "m", LO replies with " (inch) 😮
                  Uli
                    marcdurant
                    Good catch! I'll get that fixed. Must be a mismatch in our translation.
                    -Marc
                      atelierpaar
                      good morning from Germany
                      I appreciated your comments and suggestions ! ☀ !
                      Thanks for taking care of the issue Marc 😄
                      Uli
