    SU13 and missing materials
    11 Posts 4 Posters 1.9k Views 4 Watching
    • O Offline
      otb designworks
      For some reason, any skm file that I add to ~application support/sketchup 13/materials does not show up in Sketchup and all of them worked perfectly fine in SU8. I jost copy and pasted the skm files from one folder to the other.
      Is there some difference between "old" and "new" skm files?
      thought and suggestions would be highly appreciated because I am talking about probably 50 or 60 custom materials I have developed over the years.
      Cheers, Chuck
      OTB Designworks is on Youtube
      • KrisidiousK Offline
        Krisidious
        I had a few that reported and error and I just deleted them... They weren't important and they all seemed to be in one folder, so I figured there was something wrong in them. I transferred all of mine over with no issue. I'm on PC though.
        By: Kristoff Rand
        • O Offline
          otb designworks
          Weird.
          I can look in the folder and see a slew of .SKM files, but sketchup only shows me a couple of them in the materials palette.
          Pretty annoying, actually.
          Cheers, Chuck
            Krisidious
            I believe that an .SKM file is just a zip folder with an image file inside it and then the extension is changed from .zip to .skm. try changing the files to from .skm to .zip and pull out the images. then use the material importer to re-create them.
            By: Kristoff Rand
            • Chris FullmerC Offline
              Chuck, could you send me a copy of a few of the .skm's that are failing?
              Chris
              All my Plugins I've written
              • O Offline
                otb designworks
                Hi Chris, thanks for noticing this thread!
                I sent you a private message with 2 skm's that appear in the SU13 material palette and 3 that do not.
                Please let me know if you need anything further, and thanks again
                Cheers, Chuck
                  Thanks Chuck, I see this and can reproduce it as well. What I'm seeing is that SU is reading the materials from the App Bundle first, and it ignores folders with identical names in the ~/Library/Application Support/SketchUp 2013/SketchUp/Materials/ location. So to get your materials to work, you might have to change their folder names.
                  I've written this up as a bug in our database. SU should be reading from a folder called "Asphalt and Concrete" even if it exists in both the App Bundle and in the user library.
                  Thanks for pointing this out Chuck,
                  Chris
                  • O Offline
                    otb designworks
                    Thanks Chris. I will try to change the folder name to see if that works and will update with my results.
                    Cheers, Chuck
                    • O Offline
                      otb designworks
                      Changing the folder name works like a champ.
                      Thanks Chris.
                      Cheers, Chuck
                        Oh good, glad that worked. Thanks for helping us find this bug πŸ˜„
                        Chris
                        • jeff hammondJ Offline
                          jeff hammond
                          Chris
                          yeah, thats a good one to find.. i can see how it could of slipped through
                          dotdotdot
