    Raster to Vector or Sketchup importing SVG
    12 Posts 6 Posters 7.7k Views 6 Watching
    • kenK
      ken
      I am looking for a raster to vector program or a Sketchup SVG importer.
      Sometimes I get PDF files that are scanned, which means I cannot convert from PDF to DXF so I do a screen grab, either in png or jpg. I wish to convert these screen grabs to DXF.
      I have Inkscape which will export a DXF, however, I never been able to open these DXF files.
      Thanks for your reply
      Ken
      • thomthomT
        What do you want to do with these imported lines?
        In my experience these raster to vector software solutions never produce clean workable drawings for CAD drawings. There's all kinds of accuracy issues.
        • kenK
          ken
          When I get a PDF I can convert to a dxf, I use the import to make models after making sure the scale is correct.
          If I can't convert to dxf, I make a screen grab and import that into Sketchup. However, the images have wide fuzzy lines that get worst as I scale up the screen grab. So I was hoping that a vector conversion would have thinner lines and clearer lines, making it easier to measure and have a little less error.
          My screen grabs are very selective, I don't try to get the whole drawing. I usually only grab a selected part.
          I don't expect to have a clean conversion from images to vector, however, if I can get thinner and clearer lines and lines that don't enlarge when I scale the drawing I will be able to make a better model. I am under no illusion that a raster to vector conversion is going to solve the problem with scanned images, however, I was hoping to get better results.
          Ken
            I test this free one one line http://www.autotracer.org
            regulates 2 colors, 10, 10
            Save as DXF
            Import in Sketchup 6 free
            3047 edges
            No problem I have the contours πŸ’š
            πŸ˜„
            fleur.skp
            • kenK
              ken
              Thanks thomthom and Pilou
              I tried the online, and it did just what I wanted. Made the line into vectors such that scaling up they didn't get fuzzy.
              Also found WIN TOPO, free which also does the job. So now I will be able to carry on with these scanned ACAD files.
              Thanks again.
              Ken
              • KrisidiousK
                Krisidious
                I've still yet to get any good results with the ones I've tried... I have a raster to vector thread somewhere around here.
                By: Kristoff Rand
                • jarynzlesaJ
                  jarynzlesa
                  mark
                  http://www.vizualizaceschodiste.mypage.cz/
                  • KrisidiousK
                    Krisidious
                    here are some threads I've made and the responses.
                    http://sketchucation.com/forums/viewtopic.php?f=179&t=43988&hilit=+raster
                    http://sketchucation.com/forums/viewtopic.php?f=180&t=1967&hilit=+raster
                    By: Kristoff Rand
                    • kenK
                      ken
                      Krisidious
                      Thank you for your reply and you finding the old threads.
                      I have found four ways to do what I need.
                      1. WIN TOPO -Free
                      2. http://www.autotracer.org suggested by Pilou
                      3. Inkscape - I have found that Inkscape does a good job of converting PDF to DXF files.
                      4. RealDraw Pro - I have found that RealDraw Pro does a good job of tracing a bmp file.
                      All four of these solutions do an OK job. Nothing to brag about. However, I have found if I do a raster to vector conversion, and input this file and the image file in the same Sketchup file, and scale both, I get a good presentation on how to model the part. I don't try to vectorize a complete drawing just a sub set of parts. So now, I am content.
                      I make a group of the vector file, add a plane of transparent yellow over the file and redraw over the lines. By using a transparent yellow plane over the vector file I can see the lines I have drawn.
                      With a vector file I can get Sketchup to snap to ends of lines or crossing. With an image file, that does not happen.
                      Thanks to all that have replied.
                      Ken
                        Maybe you can use too the new Toposhaper by Fredo 6 for optimize the result (line broken etc...
                        • kenK
                          ken
                          Pilou
                          I will take a look at that plugin. However, I redraw the parts and now that I have a way to make a vector file, I have the lines I need to use the Sketchup snapping to line ends or centers.
                          I just wanted the vector to get snapping to work, as it didn't work on an image.
                          Thanks, I will take a look and see it the plugin make the vector file easier to use.
                          Ken
                          • R
                            rodman100
                            Scan2Cad, http://www.scan2cad.com/ has been around for a long time, but its current release Release 8.3 is not cheap. It might suit some peoples needs though, & there is a free trial. It recognises and can edit text in images and supports batch processing. Its probably one of the best available bits of software for complex raster conversions out there. It's a few years (10 maybe) since I used it but I remember it as a highly competent program. As far as I remember AutoCAD Map had raster to vector functions built in, so our office switched to that on cost grounds.
