    Mapping extruded text on curved surface
    3 Posts 3 Posters 1.2k Views 3 Watching
      AlainBo
      Hello,
      Is there a way or a plugin to map an extruded text on a complex surface.
      I mean I don't want to map a texture but to map a 3D text as shown below.
      http://img109.imageshack.us/img109/7606/pickholder2.jpg
      Regards,
      Alain
        Would this work for you?
        Top:I made a copy of the curved surface, then placed the extruded 3D text.
        Middle: I used Joint Push/Pull to extrude the curved surface to the height of the extruded text.
        Bottom: Then I put the two curved surfaces inside the text component, intersected and then deleted what I didn't want.
        It would be wise to copy the text component and scale that copy up by a factor of 1000. Then do the intersection and deleting on the large copy.
        • KrisidiousK Offline
          Krisidious
          looks great Dave.
          By: Kristoff Rand
