    Browser called from SU and html code
    11 Posts 5 Posters 812 Views 5 Watching
    • ppoublanP Offline
      ppoublan
      Dear all,
      I'm trying to build new User Input module for a pluggin. Exchange of datas between Sektchup and the webdialog are ok. But When I try to add some HTML 5 code to create better input, I'm surprised to see that the code is not displayed the same way if called from SU or just opening the HTML file with a browser.
      Here is an example (at left from a browser), at right from SU where the slider disapear:
      I initialy thought it was due to obsolete versions, so I tried from Windows 8 Pro and Sketchup 2013. Same problem.
      What is the browser and version called by SU when WebDialog is created ? Can it be changed ? What version of HTML is supported ?
      Yours
      Pascal
        SketchUp webdialogs uses the HTML engine of the host OS. Under Windows this is Explorer, under OSX this is WebKit. What they support depend on what version you have installed.
        Note that IE inside an embedded control such as a WebDialog is much more conservative in it's pick of render mode. In order to trigger the latest you need to insert a META tag. See the Lost Manual for more info: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki/Doctype---Quirks-vs-Standard-vs-Superstandard
        • renderizaR Offline
          renderiza
          If I remember correctly HTML 5 is not compatible yet with SketchUP web-dialog...I wish it was though. 😒
          Cheers!
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          • ppoublanP Offline
            ppoublan
            Thanks a lot Thom, the meta http-equiv at least corrected the thing on my PC.
            Do not know if it will work on all configurations but with this line :
            <meta http-equiv="X-UA-Compatible" content="IE=10">
            I'm able to use input of type range.
            Pascal
              It is if you have an IE version installed that support HTML5 - meaning IE10. Works great then!
              That would be a safe one if you test on IE10 and want to ensure it's always using IE10.
              If you want it to behave like in the web browser where it always uses the latest engine available:
              <meta http-equiv="X-UA-Compatible" content="IE=edge">
                It will work on all systems that have IE10 or newer installed.
                • Dan RathbunD Offline
                  Dan Rathbun
                  ... but not on XP that cannot have IE10 installed ?
                  I'm not here much anymore.
                    renderiza
                    I am really confused here! πŸŽ‰
                    I have internet explorer 10 to navigate the internet but when I use an html 5 tag on my web-dialog for Sketchup it says "Your browser does not support it".
                    Does SketchUp have separate version of internet explorer?
                    If so can you update that version and how?
                    Thanks!
                    • jiminy-billy-bobJ Offline
                      jiminy-billy-bob
                      Even while using <meta http-equiv="X-UA-Compatible" content="IE=10"> ?
                        renderiza
                        Wow! 😍
                        I was not familiar with that meta tag...I am so happy because now I can expand my webdialogs features! πŸ‘
                        Thanks!
                          jiminy-billy-bob
                          But remember :
