    LO 2013 Hybrid & Vector Render show info behind camera.
    layout
    11 Posts 3 Posters 1.0k Views 3 Watching
      Charlie__V
      All,
      I have some cross sections of a building.
      The Cross Section displays the information as expected with Raster Render.(camera position/scene)
      When Hybrid Render or Vector Render is used, information behind the camera appears.
      Best,
      Charlie
      EDIT:
      1.) Removed .png image.
      2.) Attached LO File has a very simple example of the problem that exists.
      Unwanted geometry appears when Vector or Hybrid selected
        Charlie__V
        Can anyone confirm what I am experiencing with LO 2013?
        I really like the speed increase with LO 2013 (Hybrid/Vector)...but this bug would prevent me from upgrading until it is repaired. (I have trial version now)
        Thanks,
        Charlie
        • KrisidiousK Offline
          Krisidious
          Charlie, I'm not experiencing this... and I use Vector almost entirely.
          I have tried vector/hybrid and not gotten this...
          Are you sure that your section plan goes through the entire model and not just partially through?
          By: Kristoff Rand
            Charlie__V
            Kristoff,
            Thanks....but to be clear......are you saying you have not experienced it in general?
            Or have you downloaded the attached file?
            Occurs to me I should have taken a screen shot of what I see in above LO file.
            See below
            Charlie
              JuanV.Soler
              Hi CHARLIE__V ,
              I think it is because it is necessary to explode the group first in SketchUp ,
              it worked for me
                Charlie__V
                Juan,
                Thank you for looking at this for me.
                I am not sure you understand the problem though. (most certainly my fault) 😄
                Imagine looking through a camera and snapping a picture of something.
                Develop that picture and it will contain what you saw...and only what you saw through the lens.
                Now, in LO.....and looking through the lens (SU Scene)while in Raster mode...it is as expected......only what is in front of the camera lens will be seen.
                Switching to either Hybrid or vector mode and you will now see geometry Behind the camera. (the colored shapes in above Vector mode are well Behind the camera)
                Best,
                Charlie
                  Krisidious
                  I would need the SU file to go with that won't I?
                  By: Kristoff Rand
                    Charlie__V
                    Kristoff,
                    Should be embedded.........no?
                    Rt click....open with SU.
                    Charlie
                      JuanV.Soler
                      yes we are not understanding 😄
                      this is what I get in Layout after exploding the group
                        Krisidious
                        Charlie, this is happening because you're cutting your section inside of the group. You need to cut it outside the group and make another scene for the other groups or components in the model.
                        By: Kristoff Rand
                          Charlie__V
                          Kristoff,
                          Thanks.........but this was not so in LO3.
                          Wait...Check that...seems it Was like that in LO3
                          So sorry guys 😳
                          Charlie
