    Dimensions in layout
    layout
    3 Posts 3 Posters 531 Views 3 Watching
    • zain01Z Offline
      zain01
      Hi all
      Can anyone tell me why when i try to put dimensions on my layout documents they come out very inaccurate.
      In-fact totally wrong. for example something that should be say 900mm it says its 161mm.
      Thanks in advance.
      Z
        Setting the dimensions to Auto Scale should also yield the correct dimensions. Make sure, too, that you are clicking on points on the model to avoid getting paper space dimensions.
        • KrisidiousK Offline
          Krisidious
          scale must be set to the scale of the view port to the model. right click on the model and set scale. go to dimension properties and set scale to the same thing.
          By: Kristoff Rand
