    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 164.1k Views 79 Watching
    • LOAML Offline
      LOAM
      @sob80sup81 said:
      Hello,
      Is this plugin still actively supported by the developer? I purchased a license expecting to get a more comprehensive library of trees and grass but after keying in the license, no change of tree collection from the free version.
      Would also like to know this as it doest work in SU2017
      • Bob JamesB Offline
        Bob James
        • jujuJ Offline
          juju
          @bob james said:
          [attachment=0:1xmppw8w]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1xmppw8w]
          works fine here in SU2017 as well
          • LOAML Offline
            LOAM
            @juju said:
            @bob james said:
            [attachment=0:1aq04ju1]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1aq04ju1]
            It loads fine as per your image but try the following;
            • Make a tree
            • Reconfigure it, using right click, reconfigure
            • Change tree parameters *
            • Redraw tree using updated parameters **
            • You will notice that many of the sliding bars are listed as NaN
              ** Redraw does nothing after changing any of the parameters 😞
            http://i.imgur.com/Udv6s2S.jpg
            • OxerO Offline
              Oxer
              Error in Ruby Console to load a tree:
              Error; #<NoMethodError; undefined method `treetemplatename' for nil;NilClass>
              /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1141;in `webtosu'
              /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1117;in `block in initialize'
              /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `call'
              /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `find_support_files'
              /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `populate'
              /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1137;in `webtosu'
              SketchUp;1;in `call'
              OSX 10.11.6 & SU2017
              [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
              • LOAML Offline
                LOAM
                I've had an email back from ppoublan to say he is hoping to get this fixed in the new year.
                • K Offline
                  karllarsen
                  @loam said:
                  @juju said:
                  @bob james said:
                  [attachment=0:2vnsbkfz]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:2vnsbkfz]
                  • Make a tree
                  I am having the exact same problem.
                  Less is more.
                    Jorgensen
                    has anyone got this to work with su2017?
                    thanks
                    jorgensen
                    sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
                    • K Offline
                      karllarsen
                      It sure would be nice to know if this will ever work or its just a lost-cause?
                      Less is more.
                        I don't really have a need for it but I just installed it now because of your post. It seems to work fine for me. It makes trees like it says on the box.
                          Works fine for me inside Su2017 Make ! ☀
                          Make your change(s) then Right Click on the selection / Context Menu 3D Arc Studio Tree/ Redraw.
                          Free version
                          3DArcStudio Tree Maker Sketchup Plugin can be downloaded for free from this site. The free version gives you access to all features, except you are not granted the right to sell or distribute trees created with the plugin, you will get one message each time you change configuration and little time to wait before the tree starts drawing, and you will not get access to all the tree templates included in the full version. If you like this plugin, you can get a licence for 10 euros that will remove those limits.Possible with the free version
                          Time was 5 s 😉
                          Rendered with the free SimLab Composer Light! maxi 1920 * 1080 😉 (a KeyShot like)
                          Can reload quasi any format of files! 👍
                            PS But you right : Configuration Menu works not like inside Su2016! 😮
                            Seems some parameters are not responsive like "Number of truncs"...
                            and more curious the 2 buttons Redraw and Draw Proxy!
                            So it's a very good habit to keep old versions of SU! 💚
                              mwm5053
                              I downloaded the plugin from Sketchucation store within SU just the other day and read the post about the difference between free and paid so I don't think that's the issue I'm having. The drop down list of templates shows none either for the trees or grass. May be some knows something I don't (which is entirely possible).
                              2011 iMac
                              SU 2015 Pro, 2017 Make
                              V2 Twilight
                              macOS Sierra 10.12.5
                              • OxerO Offline
                                Oxer
                                The plugin does not work on SU 2017, try with SU 2016 or 2015.
                                  If it doesn't work in SU2017, why did I get trees from it in SU2017?
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p613826
                                  It worked for Pilou with no problem either. Maybe we're doing it wrong.
                                  • OxerO Offline
                                    Oxer
                                    Perhaps because you use Windows, mwm5053 & me work on Mac, the plugin works fine in SU2016 on Mac but in SU2017 it appears the issue that mwm5053 describes.
                                      mwm5053
                                      I just removed all website data in Safari and Google Chrome ( some plugins I remembered use web dialogue something or other ) like the Fur plugin that I had problems with on Mac but still no choice for choosing type of tree.
                                      Edit the Fur plugin does work in SU 2017 and OS X 10.10.5 Yosemite
                                      2011 iMac
                                      V2 Twilight
                                        lgrahm
                                        I guess it's a Mac-related problem. I've tried to install it on both an iMac and a Macbook pro with SU2017 pro.
                                        Problem 1 is (as other have noted) that the menu is blank - you can't choose any tree type.
                                        Problem 2 is that the plugin dissapears when you quit and restart SketchUp! Yes, it's not disabled - it's not there!
                                        • K Offline
                                          karllarsen
                                          [attachment=0:2trikxvl]<!-- ia0 -->Screenshot - 2_10_2017 , 6_47_08 PM.png<!-- ia0 -->[/attachment:2trikxvl]
                                          Great! Now try to EDIT the tree and tell me if you can ADD branches.
                                          Then, make sure you read the entire description of what is NOT working 😉
                                          Less is more.
                                            mwm5053
                                            Still having the same problem as lgrahm on my Mac with SU 2017 seems to work fine in SU 2015 however.
                                            2011 iMac
                                            V2 Twilight
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
