    Don't remember of the box...
    28 Posts 9 Posters 2.4k Views 9 Watching
      I don't remember if a plug is existing for align the axe of a selection of faces Component / Group
      for have a "flat" box when this one is inclined? 😳
      • mitcorbM
        mitcorb
        Hi, Pilou:
        Maybe this? ThomThom's Draw Bounding Box
        http://sketchucation.com/forums/viewtopic.php?p=256536#p256536
          @Mitcorb
          Alas no, that'is only drawing the first box not wanted! πŸ˜‰
          • KrisidiousK
            Krisidious
            Fredo Scale I think is what you want.
            404 Not Found
            (sketchucation.com)
            or just edit the axis.
            By: Kristoff Rand
              @Krisidious
              Alas FredScale draw the good "box scaling" wished but just for showing the action and don't transform the "box"! πŸ˜‰
              Of course I can move the axe by hand but I have thousand of different faces!!!
              • KrisidiousK
                Krisidious
                Ahhh I see your problem. I don't know a plugin that does that.
                By: Kristoff Rand
                • thomthomT
                  Why do you need a plugin for this? I mean, there is the Change Axis function in SketchUp...
                  • R
                    rv1974
                    Pilou, what happened there in France? Pigments shortage? Why those printscreens weren't painted randomly in your 'eyes blowing' way? πŸ˜•
                    • thomthomT
                      πŸ˜†
                      • R
                        rv1974
                        oh no
                        http://24.media.tumblr.com/tumblr_m9zpf8rEQ11rzsuf4o1_400.png
                        • mitcorbM
                          mitcorb
                          I think what is wanted is a script that inspects all groups/comps and, while ignoring global and local axes, makes the minimum bounding box for each in one operation. Honoluludesktop had a thread related to this, but not necessarily one that acted on a large selection. I searched the string "sketchup adjust bounding box" but did not find anything specific.
                          EDIT: Ah, Pilou, you posted just as I was writing this comment.
                            YES! β˜€ (Fredo6 has calculated it for his Fredo Scale but...
                              Say I have a volume , I explode it , I want each facet is a group or a component for some actions πŸ˜‰ (I have that πŸ˜„ but not the "flat box" because the facets are inclined! 😞
                              Say give some images with transparent background to these facets so orientation to these target facets must have a "flat box" and not these volumetric bounding boxes!
                              • fredo6F
                                fredo6
                                Pilou,
                                This is an interesting idea: align axis on the minimum bounding box.
                                That would be a separate plugin because FredoScale operates only on a selection.
                                Fredo
                                  Cool, so I wait and see! πŸ˜„
                                  • PixeroP
                                    Pixero
                                    Oh, yes pleeease!!! That would be great Fredo.
                                    And maybe some kind of additional tool to flip between the respective axises.
                                      More clear ? πŸ˜„
                                      Component onto face by Chris Fullmer gives a sort of good result or the tricky Component Dropper by Thomthom (it adapt the the size of the Source to the Target! ) but i don't want use these plugins because they use just one component as source! πŸ˜‰
                                      I want to use Random Component replacement by Sdmitch for have any number of components so I need the "minimum bounding box" πŸ˜‰
                                      • E
                                        eco
                                        ...yes- it would be a very nice piece of script πŸ˜„
                                          Why? 😲
                                          It is a very nice piece of script! 😎
                                          • E
                                            eco
                                            Maybe it just me but i can't find option to create components from groups with axis set to minimal bounding box for each of new components...?
                                            • 1 / 2
