    Assign a material in the ruby console
    3 Posts 2 Posters 364 Views 2 Watching
    • C
      crustybaps
      I have tried to add a material to some of the faces in my model and I get the error material [Brick_Antique]" not found. Could someone show me the correct way to assign a material to a face
      for i in 1..10 faces[i].material= "[Brick_Antique]"
      • renderizaR
        renderiza
        Hi, here is an example;
        model = Sketchup.active_model ;
        ents = model.entities ;
        materials = model.materials ;
        m = materials.add "name for material" ;
        texture = m.texture = "c;\\Users\\User\\Desktop\\folder\\texture.jpg" ;
        m.texture.size = 60 ;
        use_texture = true ; #Change to false to use color only
        faces = ents.grep(Sketchup;;Face) ;
        faces.each do |e|
           if use_texture
              e.material = m
           else
              e.material = [190,190,190] #Use color instead of textures
           end ;
        end ;
        Note: By the way there is a Developers forum section which might get you better answers to your questions.
        Cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • C
          crustybaps
          Thanks that worked really well.
