    Copy camera settings from one scene to another?
    6 Posts 3 Posters 884 Views 3 Watching
    • U
      unearthed
      Is there a way to copy all of a scenes' camera settings from one scene to another? Sometimes I want to change an existing view to another scene (and sometimes I accidentally update duplicated scenes). The only way to get it exact seems to be to go into Camera>Advanced - and copy out each line to the scene I want to change - has this been done via a Rubie? (I've searched and found nothing)
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • J
        JuanV.Soler
        have a look , it may help you
        404 Not Found
        (sketchucation.com)
        • U
          unearthed
          Thanks Juan,
          That does more or less exactly what I want - I set up a scene with four different options in it and ReScene copied camera settings to all scenes; there's good control over what gets copied and it can be limited just to scenes, and scenes that you don't want ReScened you just deselect them in SU's animation tickbox. It will save a lot of work.
          The only thing is it's a Cadfather plugin and there are warnings on the plugins page about their plugins causing errors in SU - so I'll just install it when I need it.
          • renderizaR
            renderiza
            If there is any bugs or issues with code then I should be the one hold responsible and not CadFather since his involvement was to come up with the original idea for the plugin and produce toolbar icons & web-dialog buttons graphics.
            Be aware that the "SCF" plugins that have that warning were made years ago when a lot of people were trying to figure out what was consider good coding practice and what was not.
            Cheers! 👍
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            • U
              unearthed
              Well if that's the case, then shouldn't the warning http://sketchucation.com/forums/viewtopic.php?f=323&t=28782#CadFather on using CADFather's plugins be removed or have an updated warning message? There's some good plugins there and I'm sure I'm not the only one that's been put off loading them.
              • renderizaR
                renderiza
                If the plugin is warning have not been removed I presume its because it still can cause some problems and maybe conflicts with other plugins so it is wise to follow the advice of not installing until it gets fixed.
                Most of the issues regarding plugins comes when modifying a global variable and not putting your code under unique module so that no other plugins gets affected. I am sure there is more reason though so if you are unsure of a plugin maybe ask in the developers forum if its safe.
                Also 'SketchUcation plugin store' is great place to find safe and up to date plugin and a very cool feature is to unload plugins you are not using and load them up when you do. Here is a link to that plugin.... http://sketchucation.com/resources/plugin-store-download
                Cheers!
