    Some Light Up questions
    2 Posts 1 Posters 244 Views 1 Watching
    • newnoobN
      newnoob
      1. An odd thing in Light Up is that when I put a point light source in my model, for example a spot light then the light source itself is not illuminated.
        In the picture the little cylinders on the ceiling are the point light sources.
      2. Another issue I have with Light Up is that I can adjust the brightness of a global point light source (light goes evenly in all directions) in lumen (lm) but when I use an IES file for a light with a certain emission characteristic, I cannot change the brightness in lm - I thought this is maybe because the lights from the IES file are not only specific in there emission characteristics, maybe they are specific in there brightness too – but then the IES-files should provide information of the brightness of the light which they refer too in lumen – but they don't.
      • newnoobN
        newnoob
        I posted the same thread in the LightUp-forum and the main developer of LightUp Adam Billyard gave an aswer which at least solved the first issue.
        http://www.lightup4sketchup.com/forum/viewtopic.php?f=2&t=1272&sid=bf3311bb55dba39d75d2f40498140efe
