    Light Up Simple Mode
    2 Posts 1 Posters 201 Views 1 Watching
    • newnoobN Offline
      newnoob
      I am playing around with LightUp since 3 days or so and I can not use a lot of it's functions because LightUp is running in "simple mode".
      In a thread in the light Up forum I read that this is the case when the graphic card is to weak, but I have a "ATI Radeon HD 4800 Series" graphic card, with this card I am able to play not so old high end PC games like Crysis 2 in maximum resolution, so I think it should be more than able to handle Light Up.
      Another thing is that Light Up was not always running in "simple mode", because I can remember that I was able to change some settings which I cannot change anymore (like all the adjust color settings), when I still try to do it the message "not able in simple mode" appears.
      Well, maybe this issue is connected to a Ligh tUp crash which I had some time ago, also SU crashes here and then when I have too much stuff in one file.
      Has anybody a suggestion for a solution?
      Best Regards from Vienna
      • newnoobN Offline
        newnoob
        in the menue bar of SU under: Tools>LightUp "Simple Rendering" was checked, after I unchecked it and then checked normal rendering and restarting SU Light Up is not running in "Simple Mode" anymore
