    Find a component definition in a list
    4 Posts 3 Posters 435 Views 3 Watching
    • G
      glro
      i select an object in the model
      If it is a component, the code gets its definition and puts it in a string named "ref"
      for e in selection
              if e.is_a? Sketchup;;ComponentInstance
                  ref = e.definition.name.to_s
      then i want to compare the "ref" to strings in a list (an array?) called "references", and find the one that matches
      for z in (0..715) do
      		if references[z] == ref
      			puts "hello"
      I know there is one string among the 716 strings, that matches to "ref", but the program never says "hello", doesn't find it
      what am i missing? Is it a bug in Ruby?
      • TIGT
        Define 'ref' OUTSIDE of the block iteration
        ref=nil
        for e in selection
        Some simpler code would be
        ref=selection.grep(Sketchup;;ComponentInstance)[0]
        return nil unless ref
        Then
        references.each{|r|
          if ref==r
            puts 'hello'
            break
        OR MUCH simpler
        puts 'hello' in references.include?(ref)
        Are you sure that the exact 'name' is in the array ?
        What is 'ref' ??
        • G
          glro
          sorry for asking the question, i found the answer...
          			#rstrip to suppress whitespaces
          			if references[z].rstrip == ref
          			puts "hello"
          			end #if
          		end #for z in
          i had whitespaces at the end of references[z]; to remove them:
          52 str.rstrip
          Returns a copy of str with trailing whitespace removed.
          http://www.tutorialspoint.com/ruby/ruby_strings.htm
          funny how programming depends so much on very trivial details...
          • thomthomT
            A less verbose version:.
            <span class="syntaxdefault">result&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">references</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">rstrip&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">ref&nbsp;</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">'Hello'&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">result</span>
