    2d Export Crash need drawings for tomorrow help please
    3 Posts 3 Posters 278 Views 3 Watching
      APM-Pixel
      hi all i have a site model and modeled my structure inside it, when i export to 2d PDF to work on it in illustrator i get a crash. Ive used clean-up 3 reduced the lines tried everything, even printed to PDF and used layout and still get crashes 😞 my drawings are due tomorrow and i have no way of getting them from the model, is the a better way of doing this or a plugin i can use?
      ps im line exporting using the all white default style to turn the faces white
      thank you for your time πŸ˜„
      • KrisidiousK Offline
        Krisidious
        something has an enormous amount of detail. use Goldilocks 2.0 to find it. and remove it or reduce it's polys. http://sketchucation.com/forums/viewtopic.php?f=323&t=31881&p=408311&hilit=goldilocks#p281153
        By: Kristoff Rand
        • renderizaR Offline
          renderiza
          Also try exporting entire model by small parts using export 3D > Options > Export Selected Only.
          Hope this helps!
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
