    Help on drawing curves
    3 Posts 3 Posters 250 Views 3 Watching
    • H Offline
      Harley_130
      I'm trying to do the Woodsmith Shop Vac cart in SKU. I was buzzing right along till I got to the cover piece (see below)
      The big hole and outside radius I can do, but the curved cutout with the 3/4" radius marked I just can't get pass. I drew it a couple of time using circles on each end and then the arc tool but I couldn't get it to work, then used used the arc tool but couldn't get it to work. I know there's an answer in there somewhere.
      Your never to old to learn Sketchup, I'm living proof!
      • BoxB Offline
        Looks to me like you have three big circles and two little ones.
        Use the centre point of your big hole to draw the other two "offset circles" and the same centre point to array your two small circles.
        Use the centre line as your measurement point. Even draw your small circle on the centre line and rotate it to where you want it and then rotate a copy back the other way. Both of those circles should be fitting between the two offset circles.
