    (Architectural Plugin) PlusSpec
    44 Posts 13 Posters 15.1k Views 13 Watching
    • aadbuildA Offline
      aadbuild
      This problem appears to come when a Sketchup user is using a none English version. We are yet to confirm but this seams to be the issue from testing in our office.
      I am sorry to say the Plusspec currently works with the English version of Sketchup. We will be looking into this more. I hope that helps.
      Also Igor I noticed that you do not have a paid version of PlusSpec yet you have used a trial version sometime ago. This is where you problem stems from.
      Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
      https://www.plusspec.com
      • I Offline
        I.Aleks.S
        Hello.
        You speak about what trial version, whence you have an information that I use the trial version? Do not mislead people!
        There was no day that I managed to start yours "Plusspec" for check! And you here speak about any use...???!
        Has passed TWO weeks (with 1/23/2015 in the 2/9/2015) at you on correction of errors...!
        And even now I cannot EVEN TRY yours "Plusspec"!
        Here it I have sent in yours those support:
        Your plug-in PlusSpec was established now. BUT is not present what possibility to check up it on working capacity!
        At attempt to make activation it gives out an error and blocks all further actions, does not allow to do what changes - though how many to reboot Sketchup!
        Here an error code:
        ***%(#0000BF)[Machine: Could not load Machine ID. Please close Sketchup and try again.
        Activate/Re-activate License]***
        To have to do only full removal of it PlusSpec.
        What now yet so? That further...?
        The answer while is not present, as always, it is necessary to have patience... That it to wait.
        • utilerU Offline
          utiler
          Watched this overnight.... PlusSpec official release!
          Go play.
          Just Curious...
          • I Offline
            I.Aleks.S
            PlusSpec πŸ‘Ž πŸ‘Ž πŸ‘Ž 😳
            • 3 / 3
