    (Architectural Plugin) PlusSpec
    44 Posts 13 Posters 18.4k Views 13 Watching
      Studio Aware
      If you are an architect, designer, builder, estimator, or merely like to tinker, you must check out PlusSpec. I am in love with this program and it will change your life!
      • utilerU
        utiler
        I second that..... ๐Ÿ‘
        Just Curious...
        • I
          I.Aleks.S
          aadbuild Hello
          1/23/2015 has downloaded and has established "PlusSpec is a plugin for SketchUp" under the instruction: https://buy.plusspec.com/download "for Windows ... Metrik", But program "PlusSpec" was established incorrectly with errors;
          Error at file loading C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec/initialize.rb Error: #<ArgumentError: invalid byte sequence in UTF-8> C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/uuidtools-2.1.4/lib/uuidtools.rb:604:in []' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/uuidtools- 2.1.4/lib/uuidtools.rb:604:in block (2 levels) in first_mac' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/uuidtools-
          2.1.4/lib/uuidtools.rb:603:in map' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/uuidtools- 2.1.4/lib/uuidtools.rb:603:in block in first_mac' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/uuidtools-
          2.1.4/lib/uuidtools.rb:609:in call' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/uuidtools- 2.1.4/lib/uuidtools.rb:609:in first_mac' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:47:in apply_uuidtools_fix' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:88:in block in <top (required)>' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:30:in gracefully' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:52:in <top (required)>'
          C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load'
          C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec.rb:42:in register_extension' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec.rb:42:in module:PlusSpec'
          C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec.rb:25:in <module:Rubysketch>' C:/Users/Igor/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubysketch_plusspec.rb:24:in <top (required)>'
          What to do, how to establish?
          • TandemT
            Tandem
            Aleks,
            You will probably get a quicker response by contacting PlusSpec directly at https://plusspec.com/support/
            • I
              I.Aleks.S
              @tandem said:
              Aleks,
              NO not got (there's always a long wait for the answer), why would I want to ask here if the answer was there?!
              Tandem Can you help me?
              • KrisidiousK
                Krisidious
                Did you login to plusspec and restart sketchup?
                By: Kristoff Rand
                • TandemT
                  Tandem
                  Sorry Aleks, I do not have PlusSpec, I was just thinking that there are not that many users that use PlusSpec on this site and that is why I suggested you also try to ask for help there.
                  How long have you been waiting for a response on their website?
                  Did you try Krisidious' suggestion?
                  • utilerU
                    utiler
                    Aleks, I've PM'd the guys from PlusSpec to follow up this thread. Karel is right;; best to post directly to the PlusSpec forum if you're having issues. I always get a response from there....
                    Just Curious...
                    • aadbuildA
                      aadbuild
                      Igor we always get back to our users. We have encountered this problem once before yet can not replicate on the 30 plus computers with the same spec as yours in our office. Do you have time to contact us today? we will actually log into your computer remotely and do our best to fix it. It would be great to know why 1 in 1000 computers does this and you could really help us. In return we will extend your license for free.
                      I am talking with the developer as I type and he is asking what the system language is set to ?System language
                      And what Language of Sketchup did you buy?
                      Could you please go to the forum, I pay someone full time to check it yet I can not pay 30 people to check every forum every minute of the day.
                      Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                      https://www.plusspec.com
                      • aadbuildA
                        aadbuild
                        This problem appears to come when a Sketchup user is using a none English version. We are yet to confirm but this seams to be the issue from testing in our office.
                        I am sorry to say the Plusspec currently works with the English version of Sketchup. We will be looking into this more. I hope that helps.
                        Also Igor I noticed that you do not have a paid version of PlusSpec yet you have used a trial version sometime ago. This is where you problem stems from.
                        • I
                          I.Aleks.S
                          Hello.
                          You speak about what trial version, whence you have an information that I use the trial version? Do not mislead people!
                          There was no day that I managed to start yours "Plusspec" for check! And you here speak about any use...???!
                          Has passed TWO weeks (with 1/23/2015 in the 2/9/2015) at you on correction of errors...!
                          And even now I cannot EVEN TRY yours "Plusspec"!
                          Here it I have sent in yours those support:
                          Your plug-in PlusSpec was established now. BUT is not present what possibility to check up it on working capacity!
                          At attempt to make activation it gives out an error and blocks all further actions, does not allow to do what changes - though how many to reboot Sketchup!
                          Here an error code:
                          ***%(#0000BF)[Machine: Could not load Machine ID. Please close Sketchup and try again.
                          Activate/Re-activate License]***
                          To have to do only full removal of it PlusSpec.
                          What now yet so? That further...?
                          The answer while is not present, as always, it is necessary to have patience... That it to wait.
                          • utilerU
                            utiler
                            Watched this overnight.... PlusSpec official release!
                            Go play.
                            ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                            Just Curious...
                            • I
                              I.Aleks.S
                              PlusSpec ๐Ÿ‘Ž ๐Ÿ‘Ž ๐Ÿ‘Ž ๐Ÿ˜ณ
                              • 3 / 3
