    Marseille velodrome stadium roof
    10 Posts 3 Posters 2.3k Views 3 Watching
    • masterpaulM Offline
      masterpaul
      http://i.imgur.com/cfiTIRL.jpg
      http://i.imgur.com/FG4KQG9.jpg
      http://i.imgur.com/gG41WQD.jpg
      I've been trying to figure out how to do a stadium with the same type of "flowy" roof (with the trusses); presented in the render. I tried radical bending however I couldn't get the shape right. Could someone explain to me step by step how to create a roof like this?
      Thanks in advance.
        see some extrude edges tools by tig πŸ˜‰
        http://sketchucation.com/forums/download/file.php?id=47633&mode=view/rokbox.jpg
          masterpaul
          Extrude tools wont really give me a true truss. The end result will just be a grid. This would need to be something like a spaceframe.
          Edit: Didnt see the attached pic. Ill try this out.
            masterpaul
            I just tried producing the roof using the extrude tools, with no success. I seem not even be able to get the basic shape right.
              masterpaul
              So I figured a possible way this may be done:
              Basically loft skinning the shape, and clicking the generate with pseudo quads. Then selecting the lines and turning them into tubes.
              However this happens when loft skinning:
              http://i.imgur.com/p1gPWge.jpg
              After skinning; on the right. Before skinning on the left. The geometry does not match the lines at all.
              • ely862meE Offline
                ely862me
                You could try like this : make the inner shape, then use Offset tool from Tools on surface to create the outer shape, then connect the two shapes with lines and replace the lines with components.
                Elisei (sketchupper)
                Come and See EliseiDesign
                  masterpaul
                  YES! I think Ive got it!
                  We both think alike πŸ˜„
                  I made the inner shape using the loft skining. Now Im fixing up the geomerty πŸ˜„
                  And letter as you said Im gonna offset it πŸ˜„
                  • ely862meE Offline
                    ely862me
                    Or, you could create the skin between the inner and outer shapes with Curviloft with how many segments you want, then extrude this skin with Joint push/pull ,then you have to add some extra lines for your desired effect.
                    I used lines,arcs,circles to cylinder plugin to create the structure although I would have used something to create squares or rectangular profiles .
                      masterpaul
                      Is there a plugin that does that?
                      • ely862meE Offline
                        ely862me
                        Not as far as I know; I copied, scaled and rotated them manually !
