    Scale and rotate
    extensions
    3 Posts 3 Posters 507 Views 3 Watching
      MoritzH
      If it s already out there, i m sorry. but please send me a link. i am looking for a plugin with wich you can press ctrl while scaleing to copy as well. and one where you can fix the rotation axes with the cursor buttons.
      thank you.
        mitcorb
        Hi:
        In the Plugins Index, found under the Resources header at the top of the page above, you can find the following:
        Simple Shell by Jim - http://sketchucation.com/forums/viewtopic.php?t=33169
        Shell by thomthom-- http://sketchucation.com/forums/viewtopic.php?t=39308
        As far as I can recall, neither of these requires that you press the Control button
        Maybe one or the other will answer your first request.
        If I understand your second request, Is it not possible simply to press the up down left right arrows to set your direction? Or do you mean axial reference not on the global axes? What about the Alt button?
        You may want to update your User Profile. It can suggest information for the real experts to help you.
        • P Offline
          ELse you have Grow by Tig who can make any combinaison of Move, Scale, Rotate in the same time and more! 😉
