    VRay - Bluish color after rendering - Help needed
    extensions
    4 Posts 3 Posters 792 Views 3 Watching
    • P Offline
      pedroines
      Dear Vray experts
      Unexplainable the renders on the model I am working in start getting Bluish as can be seen it the attached picture...
      I am for 2 weeks playing with the settings and can get no improvement..
      I tried with previous versions of the same model I did last year and worked fine with normal colours..
      Does any one of you experiment such challenge?
      I don't know what to do more...I am desperate
      Any help will be highly appreciated
      Jose Palma
      • CadFatherC Offline
        CadFather
        it looks so weird that it doesn't seem a vray problem (at any rate i never experienced anything this bad, and when it fails, a restart or importing the model into a new empty file does the job).
        • andybotA Offline
          andybot
          can you post some screenshots of your lighting source settings. If you are using an HDR for your global illumination, try using a different one.
          • P Offline
            pedroines
            Hi CadFather
            You are right,it wasn´t a Vray problem 😡 ...In fact after my post I start a new sketchup file within the same open session, rendered it with the existing vray settings and magic..it works like a charm.
            Conclusion - It was a Sketchup problem
            Then I visit the book http://www.aidanchopra.com/book-info and made a complete new set-up of shadows and geo-positioning of model and after a few tweaks the model is back rendering without problems - see sample.
            Thanks for your input
