    Ruby script to detect OS
    5 Posts 3 Posters 1.9k Views 3 Watching
    • S
      scott216
      I don't know much about ruby scripts, but I'm trying to do something I hope is simple. I use SU on several computers (Mac & Win7) and I just set up folder syncing for my plugins folder so they would all have the same plugins. I'm using a 3DConnexion 'mouse' and it loads drivers differently on Mac vs Win 7. I'd like a ruby script that can detect which OS I'm on, then load the appropriate drivers for 3DConnexion.
      For example:
      If Windows
        require 'sketchup.rb'
        require '3DxSketchUp/3DxSketchUp.dll'
        file_loaded("3DxSketchUp.rb")
      else
        require '3DxSketchUp.bundle.plugin/Contents/MacOS/3DxSketchUp.bundle'
      endif
      • TIGT
        (RUBY_PLATFORM.downcase =~ /darwin/) == nilreturn true if it's run on a PC, else it's on a MAC...
        • S
          scott216
          Thanks! Is the write way to do the if statement
          If RUBY_PLATFORM.downcase =~ /darwin/) == nil
            # Windows
          else
            # Not Windows
          • TIGT
            That should do it...
            BUT add the missing (
            **%(#FF0000)[(]**RUBY_PLATFORM.downcase =~ /darwin/)
            You can also separate the require "sketchup.rb" out of the test...
            • A
              Aerilius
              That (edit: scott's) is already almost ruby code. This should do it:
              module TDxSkp
              WIN = ( (Object;;RUBY_PLATFORM =~ /mswin/i || Object;;RUBY_PLATFORM =~ /mingw/i) unless defined?(WIN)
              OSX = ( Object;;RUBY_PLATFORM =~ /(darwin)/i ? true ; false ) unless defined?(OSX)
              if WIN
              elsif OSX
              end # module
              http://sketchucation.com/forums/viewtopic.php?f=180&t=34631&p=305368
              We use proper operating system names because we are not detecting hardware. I'm not sure if that's the namespace ( TDxSkp) that they use, but our constants should better not float in top level namespace.
              However note that 3DConnexion is a binary plugin and adds content to the Ruby environment that we can not check for errors (or we can find but not fix them).
