    Nested groups
    6 Posts 3 Posters 371 Views 3 Watching
    • bomastudioB Offline
      bomastudio
      Hi all, I need some help in understanding nested groups.I have to build something like as follows:
      LEVEL_0 (a group)
      |_____ OBJECTS_TYPE_1 (a group)
      |_________ OBJ_1a (a group)
      |_________ OBJ_2a (a group)
      |_________ ...
      |_________ OBJ_na (a group)
      |_____ OBJECTS_TYPE_2 (a group)
      |_________ OBJ_1b (a group)
      |_________ OBJ_2b (a group)
      |_________ ...
      |_________ OBJ_mb (a group)
      So I used:
      @level[0] = SkecthUp.active_model.active_entities.add_group()
      @level[0].name="LEVEL_0"
      @sublevel1 = @level[0].entities.add_group
      @sublevel1.name = "OBJECTS_TYPE_1"
      @sublevel2 = @level[0].entities.add_group
      @sublevel2.name = "OBJECTS_TYPE_2"
      # loop code for geometry generation
      i=0
      n=5
      @type1=[] # I waant to store OBJECTS_TYPE_1 into an array for further processing
      @type2=[] # same ...
      n1=0 # incremental number of OBJECTS_TYPE_1
      n2=0 # incremental number of OBJECTS_TYPE_2
      while i < n
          pts << [xj,yj,zj]  # xj, yj, zy getted from other part of my script
          if (layer=="TYPE_1")
              @OBJ_1a = @sublevel1.entities.add_group
              ent1=@OBJ_1a.entities
              @type1[n1] = ent1.add_face(pts)
              @type1[n1].pushpull(hpil,false)
              if n1<9
      		@OBJ_1a.name= "OBJ_0" + (n1+1).to_s + "a"
      	else
      		@OBJ_1a.name= "OBJ_" + (n1+1).to_s + "a"
      	n1 += 1
          elsif (layer=="TYPE_2")
              @OBJ_2a = @sublevel2.entities.add_group
              ent2=@OBJ_2a.entities
              @type2[n2] = ent2.add_face(pts)
              @type2[n2].pushpull(hpil,false)
              if n2<9
      		@OBJ_2a.name= "OBJ_0" + (n1+1).to_s + "b"
      	else
      		@OBJ_2a.name= "OBJ_" + (n1+1).to_s + "b"
      	n2 += 1
      Running my code I get an error
      Error: #<TypeError: reference to deleted Group>
      The error is on line
      of the code above. What is wrong?
      • Dan RathbunD Offline
        Dan Rathbun
        As soon as you make an empty group.. you must ADD something to it in the next statement or two.
        A cpoint is often used.
        If you don't,.. SketchUp will delete the empty group automatically.
        I'm not here much anymore.
          As Dan says... an empty group won't last for long.
          Add something like this:
          @sublevel1.entities.add_cpoint(ORIGIN)
          immediately after making the group [you need to do it for every 'empty' nested group]...
          You won't need to do it where you add a group into a group etc, as then that means the container-group is no longer empty as it contains a nested group!
          Then to tidy up later, after there is some geometry inside the group, use something like:
          group.entities.erase_entities(group.entities.grep(Sketchup::ConstructionPoint))
          to delete the cpoint [substitute the 'reference' needed, where I have used 'group']
            bomastudio
            Thank you Dan!!! πŸ˜„
              bomastudio
              Thanks TIG!! Now all the world is clear as a sunny day!!! β˜€
              I'm going to correct my code..... πŸ‘
                bomastudio
                😍 😍 THANXXXXXXXXX!!!! it works!!!!!!
