    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 69.0k Views 16 Watching
      smicha
      Works like a charm! 😍
        smicha
        Help Rafa! - please make it work under 2014.
          What makes you think it doesn't already work in v2014 ?
          I just installed it from the PluginStore and it seems fine πŸ˜•
            smicha
            TIG,
            my fault. I tested it on a group instead of a component. It works like a charm.
              mxd1970
              It's a pity that it doesn't work on Mac.
                cleavermike
                Is it not possible to use GOSU in Sketchup Viewer or am I doing something wrong? I am setting components with a URL which works great with Sketchup Pro but doesn't in Viewer.
                Mike
                  Mr Timberdude
                  Thanks for this, its a great tool! I use it on construction projects to link in structural drawings that are related to the item you are viewing. This works great when we keep our models on one computer, but if I transfer the model and files to another computer it won't stay linked to the files I selected before. Is there a way to go in a quickly change the file location maps? or a way to keep it linked when it gets loaded up to another computer? I hand over models to our guys building, so they can get a deeper understanding of the building.
                  Thanks!
                    reneschepers
                    Good afternoon Renderiza
                    Thanks for you beautiful program
                    I would like to share my drawing with linked photos with other persons. But the photos have an absolute link to my hard-drive so when transferring the drawing and photos to another PC the links will no longer work. Is there a way that the location for the photos can be made relative to the location where the drawing is stored ?
                    Thanks in advance,
                    Rene
                    • O Offline
                      Oly80
                      This is a great tool! is there anyway the information saved to a component be retained when saving out to a component library? I have loads of technical components that my team use to build with and if would be great if the GOSU info was there when a component was pulled in?
                      • 4 / 4
