    Ruby to open a sequence of files - run ruby
    8 Posts 3 Posters 604 Views 3 Watching
      tallbridgeguy
      Is it possible to make a ruby that opens a sequence of files and then runs a ruby?
      For example, I am in a sketchup file called bob_000001.skp. (Starting file)
      Run ruby in this file
      It opens bob_000002.skp and runs a ruby. (all files in same directory)
      Then it loops to the next file, opens bob_000003.skp and runs ruby, etc
      This would continue until it runs out of files.
      something like this (sorry I'm not proficient in ruby)
      require 'sketchup.rb'
      model = Sketchup.active_model
      title = model.title
      open title + 1
      run ruby
      repeat
      Thanks!
      TBG
      Nielsen
      http://www.tallbridgeguy.com/
        Yes.
        There are 'batch tool' methods that can do this.
        Often used for batch exporting/converting, batch unit-changing etc...
        I've made a few... you just need to change parts of the ruby to do what you want then decide if you save changes etc before opening the next one etc, depending on what want the batch process to do...
        Search the Plugins at SCF and see what suits your needs best...
          tallbridgeguy
          Thanks! i will take a look. (now that I know it will work)
          Edit
          So I want to open a file like
          open bob_0000001.skp
          run a ruby
          open bob_000002.skp
          run a ruby
          etc
          Since I am just learning ruby, this is what I have so far ( I will update as I learn)
          model_filename = File.basename(model.path) #current open filename bob_000001.skp to start
          Loop
          name = model_filename.slice!(/\d+/) #splits out 000001 as a string? need a number?
          #add a number - doesn't work but thats the goal
          bob = name + 1
          run ruby.rb here # other ruby in plugin directory
          #open next file i.e. bob_000002.skp
          Sketchup.open_file "bob_" + bob ".Skp"
          repeat until I run out of files...
          goto loop
          Nielsen
            tallbridgeguy
            would this code run a .rb file for every sketchup file in a directory?
            Dir.glob('/path/to/dir/*.skp') do |rb_file|
            do work on files ending in .skp in the desired directory
            This is kinda what I would like but I can't seem to get it to work.
            s
            Nielsen
            • Dan RathbunD Offline
              Dan Rathbun
              Dir.getwd() returns the current working directory
              Dir.chdir( dirpath ) changes the working directory to the argument.[list]can be an absolute path, or a relative path from the current working directory.
              SketchUp usually starts with the User's home directory set as the WD. BUT DON'T count on that, ... any script can change it.
              RULES:
              (1) Don't assume the WD is what you need it to be.
              (2) Save the current WD before your code changes it.
              (3) Change it just before you need it.
              (4) Restore the old working directory, when done.
              πŸ’­
              I'm not here much anymore.
                tallbridgeguy
                Thanks Dan, I appreciate the help.
                One of the things I can't figure out is how to say "no to saving file" in ruby code.
                I open a file, run a ruby, and when I want to go to the next file it asks "do you want to save your file".
                How do you bypass this?
                Thanks!
                Stuart
                Nielsen
                  Dan Rathbun
                  @tallbridgeguy said:
                  I open a file, run a ruby, and when I want to go to the next file it asks "do you want to save your file". How do you bypass this?
                  Don't modify the model !
                  Well.. seriously this is true.
                  But you can save out the model to a temp file (in the working directory:
                  Sketchup.active_model.save("Temp_#{model.name}.skp")
                  Or if you wrap what you've done in a UNDO operation, then you can undo it.
                  Sketchup.undo()
                  Or to just return to an unmodified state:
                  Sketchup.undo() while Sketchup.active_model.modified?
                    tallbridgeguy
                    πŸ˜„ Thanks Dan, this worked great!
                    Stuart
                    Nielsen
