    Problem with shadows
    5 Posts 2 Posters 332 Views 2 Watching
    • grizzlerG
      grizzler
      This problem is a new one on me. If you look at the attached image you'll see that I have two floating "footprint" shadows - one on the bbq and one leading to the door. What have I done wrong to cause this to happen?
      Thanks as always,
      G
      • BoxB
        It looks like your model is placed below the ground plane.
        • grizzlerG
          grizzler
          You're correct and this is intentional due to excavation work, but why does it have this effect when the "Google Earth Snapshot" layer is turned off? What can I do to fix it other than make the garden higher than it will actually be?
          • BoxB
            In the shadows dialog box, un tic Display on ground.
            • grizzlerG
              grizzler
              Perfect, thank you.
