    Importing Floor Plans
    3 Posts 3 Posters 230 Views 3 Watching
    • K Offline
      kellieshelton
      From what sources can you import external floor plans from? What is the best method to do so?
        Use SketchUp Pro and import a CAD file. The lines come in as vectors and are ready for editing. Run Make Faces and create the faces required to Pull the walls up to 3D.
        • pbacotP Offline
          You can also try to import files in the DXF format in the free SU version using this plugin: http://sketchucation.com/forums/viewtopic.php?f=323&t=22199&hilit=dwg+importer#p186621
          And use it the same way you'd use dwg. dxf and dwg are common CAD file formats based on AutoCAD, but often available for exporting from other CAD packages.
