    How to overcome difficulty of selecting edges only
    6 Posts 5 Posters 440 Views 5 Watching
    • H Offline
      Helstar84
      I am a beginner to Sketchup and I am currently learning how to make windows, however, you need to select the edges of a square once you've deleted the face in order to make the window. But I can't manage to select just the edges of that window and not everything else. Have tried shift+clicking but it doesn't seem to work, nor does zooming right in. I think its more difficult to select the horizontal lines rather than the vertical.
      Can anyone save me from these early time wasting troubles??
      • broomstickB Offline
        broomstick
        When you need to select the edges of a square, simply doubleclick on the face of the square: this selects the face AND the border edges. Now you shift click on the face to exclude it from the selection πŸ˜‰
        • cottyC Offline
          cotty
          You should also read through this help site, there are many tips.
          If you need to go further, Thomthoms selection toys do a great job here too.
          If you often need to select difficult pathes, you should have a look at Dales SketchUV ($), which has a "Path select tool"
          my SketchUp gallery
          • Jean LemireJ Offline
            Jean Lemire
            Hi Helen, hi folks.
            Broomstick gave you one very good and quick way of doing the selection of the perimeter of a face but, as you stated it, you have deleted the face.
            I would suggest not deleting the face first. Keep this as the last operation.
            Just ideas.
            • H Offline
              Helstar84
              Thanks to all who replied, you guys are fantastic! its nice knowing there is a whole Sketchup community out there! look forward to participating further and will let you know how I go in terms of solving the problem!!
              • pbacotP Offline
                I find when making windows that it is easier, inside the window component to keep the "raw" edges of the cutting rectangle or shape , then all the other parts of the window are also components. It helps in keeping the window "cutting" and work on the parts of the window later on. At the start this rectangle of edges might be a part of the window pieces, but I separate it out.
