    Random push pull
    4 Posts 3 Posters 557 Views 3 Watching
      mics_54
      Under what circumstances would I need to select a face without selecting the bounding edges in a push/pull operation?
      • Wo3DanW Offline
        Wo3Dan
        @mics_54 said:
        ..... selecting the bounding edges in a push/pull operation?
        Push/Pull is an operation on faces. Or better said, on a single face. Don't include any edges at all. If you select a face plus an edge not being part of it's circumference, that the tool's face pre_selection is turned off for that face. Meaning that it again selects what face you are hovering over.
        Circumference_edges though may be included in the pre_selection of a face.
          But you have some plugins of random Push Pull 😉
          Didier Bur inside his fist Projection (a must to have)
          And by Jim / Tig
          Else for example the new plug Quick Lathe by Trogluddite who need only face without perimeter!
            mics_54
            The reason I ask is that I am using randompushpull.rb and wasn't sure if I selected an entire subdivided face including all of the associated edges in that subdivided face that it would make a difference on how the script worked or the resulting elements....but in testing it appears there is no difference.
