    Cricket for SketchUp; could this be true?
    49 Posts 13 Posters 8.2k Views 13 Watching
    • plot-parisP
      plot-paris
      Hi jolran,
      sounds really exciting. I am looking forward to a bit of alpha-testing πŸ˜‰
      such a plugin would be awesome indeed!
      PS: the "Cricket"-name of the april fools prank isnt too bad, actually...
      • jolranJ
        jolran
        Hi Plot-Paris.
        This can take a while.. But thanks for showing interest!
        I'm planning, testing and reading up on JQUERY events a lot at the moment so it's no standstill, just needs a lot of staging since the GUI has to be kept in a dynamic
        nature. Even if starting small..
        Today I took a break from troubleshooting though and worked on OPEN_GL lines and flatshaded meshes as per Thomthoms suggestions. Pretty cool indeed. Could prove very useful.
        Using 4 rgbvalues gives a nice transparent and not so dull looking mesh.
        1 big problem is to bridge SU and JS in a flexible yet fast way.
        And it still has to work with Mac who has sync problem with many callbacks.
        It's also difficult to pump the values from within SU when the DOM is dynamic. I.e number of nodes and combinations, ID's is unknown beforehand. Maybe pump a big JSON...
        Lazy VS eager evaluation.. etc..
        BTW using the name "Cricket" on this Interface is a lawsuit creeping around the corner. πŸ˜‰
        Gotto distance myself a little there...
        Like I said earlier, I'll probably start a new thread soonish, if all goes well.
        • jolranJ
          jolran
          I believe some of these posts can be moved to NodebasedWIP topic ?
          • D
            dmatho
            Nice, in my opinion you should simply go for it! At this point, you're probably well ahead of the game developing such a desirable feature πŸ˜‰
            Many thanks, cheers,
            . Diego .
            • thomthomT
              In TT_Lib2 I have a GUI framework where I build the UI with Ruby classes. Then the webdialog opens the Ruby side pushes messages to create the UI dynamically on the JS side. The Ruby side creates the ID for the control which is used on both sides to look up the correct corresponding UI element.
              • jolranJ
                jolran
                Thanks Thomthom I'll look into that. Although everything is very eventdriven by Jquery UI.
                • thomthomT
                  There's many ways to do it. But whatever creates the ID you can create an ID map (hash) on each side so either way know what ID to call.
                  • plot-parisP
                    plot-paris
                    Hey Joel,
                    is there already a dedicated thead somewhere?
                    Any progress on the plugin development? πŸŽ‰
                    • jolranJ
                      jolran
                      Hi Plot-Paris!
                      Yes, all discussion should be directed to:
                      404 Not Found
                      (sketchucation.com)
                      I'm working on it almost every day. Some days more some days less.
                      There's a lot of work to be done to the core,
                      but I do have some nodes responding to chaining in Ruby.
                      Is there any specific question you having? Go ahead and post it in the other thread πŸ˜„
                      • 3 / 3
