    Cricket for SketchUp; could this be true?
    49 Posts 13 Posters 7.2k Views 13 Watching
      @jolran said:
      It turned out that the connectionplugin do not create DOM elements or rather JQuery objects 😲 . So had to find some fancy Jquery selectors to convert the elements for "parler".
      What fancy selectors? Swapping between jQuery and DOM objects is trivial. Are you doing too much work?
      @jolran said:
      I notice I'm raping this topic quite a bit. Might create a new topic later on IF I get some good news or a testversion(that might delay) to play with. Sort of WIP maybe?
      This topic was based on an April Fool's prank. It'd served its purpose. But if you want to keep the discussion grouped in a separate thread then let me know if you want me to move some of the comments from this thread to another.
      • jolranJ Offline
        jolran
        Thanks Pilou β˜€
        Don't know, it wasent obvious how to go about.
        The connector JS-plugin has it's own namespace.
        So I could not slam id or class selectors on the connector. The connector had it's own special object Id where I could extract "source" as the DOM object connected to this connector πŸ˜„ And from there use whatever Jquery selector needed.
        Just took a while to figure out..
        I will do that. But I think it will be ok to start an empty topic.
        First I got to see where this can lead to. Then gotta figure out a name.
        Cockroach ? πŸ˜„ Just kidding. I don't think it's a good idea to have a name that has a bug in it.
          dmatho
          ... But I think it will be ok to start an empty topic... Then gotta figure out a name. Cock-roach ?
          David Rutten, who initially developed what's now known as Grasshopper, called it "Explicit History Editor", the reasoning being it was that the UI allows graphically remapping processes and workflows ("the History"), irrespective and beyond actually creating and editing 3D geometry.
          The actual product name may come later (!?), I'm just providing, of you will, the background principle or spirit that's driving this brand-new usability for SketchUp, behind the scene.
          Cheers,
          . Diego .
          • jolranJ Offline
            jolran
            "Explicit History Editor". Aha there you go.
            That name doesent really sell any numbers πŸ˜„
            Thanks for the info.
              DOD3R
              Hi Jorlan,
              This will be a gamechanger !!! and much better than Christmas. πŸ˜„
              PS: I volunteered for beta testing your hatchface/paneling plugin, but I discovered that I am not able to provide you with constructive feedback due to lack of experience with plugin development. I am just sketch up enthusiast with architectural education. So I am not very useful betatester at this stage, but I hope I can help later. May by I can do some UI design stuff or You name it I would be more than happy to help make parametric modeling available in SU.
              • jolranJ Offline
                jolran
                Thank you, but I can't make any promises this will become a useful working plugin.
                But, I'm sure you can provide constructive feedback. I don't have much experience in plugin development either, really. Just hacking away, solving problems when they come...
                Just a simple matter to test if the plugin works on your system could be of big help.
                I'll let you know when there's something to test.
                All the best.
                • plot-parisP Offline
                  plot-paris
                  Hi jolran,
                  sounds really exciting. I am looking forward to a bit of alpha-testing πŸ˜‰
                  such a plugin would be awesome indeed!
                  PS: the "Cricket"-name of the april fools prank isnt too bad, actually...
                  • jolranJ Offline
                    jolran
                    Hi Plot-Paris.
                    This can take a while.. But thanks for showing interest!
                    I'm planning, testing and reading up on JQUERY events a lot at the moment so it's no standstill, just needs a lot of staging since the GUI has to be kept in a dynamic
                    nature. Even if starting small..
                    Today I took a break from troubleshooting though and worked on OPEN_GL lines and flatshaded meshes as per Thomthoms suggestions. Pretty cool indeed. Could prove very useful.
                    Using 4 rgbvalues gives a nice transparent and not so dull looking mesh.
                    1 big problem is to bridge SU and JS in a flexible yet fast way.
                    And it still has to work with Mac who has sync problem with many callbacks.
                    It's also difficult to pump the values from within SU when the DOM is dynamic. I.e number of nodes and combinations, ID's is unknown beforehand. Maybe pump a big JSON...
                    Lazy VS eager evaluation.. etc..
                    BTW using the name "Cricket" on this Interface is a lawsuit creeping around the corner. πŸ˜‰
                    Gotto distance myself a little there...
                    Like I said earlier, I'll probably start a new thread soonish, if all goes well.
                    • jolranJ Offline
                      jolran
                      I believe some of these posts can be moved to NodebasedWIP topic ?
                        dmatho
                        Nice, in my opinion you should simply go for it! At this point, you're probably well ahead of the game developing such a desirable feature πŸ˜‰
                        Many thanks, cheers,
                        . Diego .
                          In TT_Lib2 I have a GUI framework where I build the UI with Ruby classes. Then the webdialog opens the Ruby side pushes messages to create the UI dynamically on the JS side. The Ruby side creates the ID for the control which is used on both sides to look up the correct corresponding UI element.
                          • jolranJ Offline
                            jolran
                            Thanks Thomthom I'll look into that. Although everything is very eventdriven by Jquery UI.
                              There's many ways to do it. But whatever creates the ID you can create an ID map (hash) on each side so either way know what ID to call.
                                plot-paris
                                Hey Joel,
                                is there already a dedicated thead somewhere?
                                Any progress on the plugin development? πŸŽ‰
                                • jolranJ Offline
                                  jolran
                                  Hi Plot-Paris!
                                  Yes, all discussion should be directed to:
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=51698
                                  I'm working on it almost every day. Some days more some days less.
                                  There's a lot of work to be done to the core,
                                  but I do have some nodes responding to chaining in Ruby.
                                  Is there any specific question you having? Go ahead and post it in the other thread πŸ˜„
                                  • 3 / 3
