    3D Prog to import an xml file?
    4 Posts 4 Posters 462 Views 4 Watching
      3eighty
      Can anybody think of a 3D program that will import an XML file?
      Thank you
      Richard
      3eighty
      • J
        john.warburton
        There are application specific flavours of XML, so there is no simple answer. I use MicroGDS, which imports and exports XML, but I doubt that it would work with just ANY XML file. I understand that Microstation also imports and exports XML.
        Life's a reach, and then you gybe.
        • TIGT
          Perhaps look at 'Blender', with an XML importer add-on... e.g. http://www.rigsofrods.com/threads/102229-xml-into-blender
          From there you can get it output and usable in a SKP ?
          • A
            Aerilius
            You need to tell us first what type of xml file it is, or from what program you obtained it. XML is a very general data structure format, it is not limited to any type of content. For example this forum is "sort of" xml, but you wouldn't want to feed a 3d program with it.
