    Problems with adding new textures on a mac
    13 Posts 4 Posters 932 Views 4 Watching
    • sallyS
      sally
      I'm trying to add some new textures to my paint bucket on a mac. If I right click in, for example, "wood", nothing happens. The only place I can right click and get the option of add new texture is in the "colours in model" tab.
      I have managed to do this before, so I know it is possible, but can't work out what I am doing wrong this time.
      Can anyone help please? Thanks, Sally
      • gillesG
        gilles
        This is here.
        • sallyS
          sally
          Salut Gilles,
          thanks for your reply, in all texture collections apart from 'in model' this option is greyed out. I don't know why.
          this is what I'm getting
          • gillesG
            gilles
            Don't know, have you tried saving then restart SU?
            • R
              rspierenburg
              I believe the material has to be in use already before you can edit it. Same for SU for PC.
              Try adding the material to a face first, and then edit it.
              Rob
              • R
                rspierenburg
                Sorry I misread the original post. This will allow you to modify a texture. There should be a button that says something to the effect of "Open or Create a Collection." Or you can import an image as a texture.
                • sallyS
                  sally
                  Hi again,
                  I tried bringing the textures into a model and again I can get them into the in model collection but could not add them to existing texture collections, as the add new texture function was still greyed out.
                  However, I can add them by adding a "new list" and then adding them into that new list. So it seems I can create new textures in my own new lists, but not add them to the default Sketchup ones.
                  I then tried to delete a list, and got an error message saying it couldn't be deleted, but it did in fact delete.
                  see attached screen shots. Hope this helps anyone else on a mac trying to get new textures.
                  add new list deleting a list
                  • gillesG
                    gilles
                    I have the same message if I try to delete a list and it delete it but have no problem importing a new texture.
                    Did you try closing Su then re-open?
                    Is this the case with another model?
                    • sallyS
                      sally
                      Hi Gilles,
                      Yes, I've tried a restart, but still can't add new textures to a current file, it's always greyed out. I can get new ones, as I said, but it does seem a little strange that I can't add to existing collections. And it is the same in any SU file, new or existing. Thanks for your continued help, Sally
                      • wind-borneW
                        wind-borne
                        @sally said:
                        Hi Gilles,
                        Sounds like you don't have permissions set for read and write for Materials folder(HD path).
                        You are able to create new lists and add to those ok which are normally stored in the other Materials folder(user path).
                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                        %(#BF80BF)[SU 8 pro
                        • sallyS
                          sally
                          Wind-borne, you were right and that has sorted it. I have had lots of permissions issues since upgrading to Mountain Lion, and that explains why I could do this before and then couldn't! Many thanks.
                          • gillesG
                            gilles
                            I will keep this in mind.
                            Sally, as your are french or live in France, did you sign up to the french sub-forum?
                            • sallyS
                              sally
                              Hi Gilles,
                              I live in France but I am English. And I haven't joined the French sub-forum, as it's much easier for me to communicate in English. But I did try to reply (in not too perfect French) to a question recently!! Thanks for your help with my issue. Merci mon p'tit loup!
