    Shape bender problem
    10 Posts 7 Posters 1.7k Views 7 Watching
    • tibetT Offline
      tibet
      hi,
      shape bender plugin is really great, but somehow i can´t start working 😞
      i may do something wrong, so i´d be grateful for any tips or suggestion
      to fix it.
      thanks in advance!
      http://img.sceper.eu/images/Ma8G6.jpg
      shape_bender.skp
      SU 2015 Pro on Win10 x64
      • ely862meE Offline
        ely862me
        Can't make it work either !
        Elisei (sketchupper)
        Come and See EliseiDesign
        • sdmitchS Offline
          sdmitch
          Took a few tries and flipping the start/end points of both the reference line and the curve but was finally able to get it to work.
          My experience has been that things work better on the XY plane so laying the curve down and standing the component up is usually the best. Also, make everything the same length. Select the curve and get its' length from Enity Info and adjust the reference line and component/group to match.
          shape_bender.skp
          http://sdmitch.blogspot.com/
          • tibetT Offline
            tibet
            hi sam,
            thanks for your invaluable help, it finally works !
            first, i thought it may be caused by another unfriendly plugin:-)
            it´s great pleasure to have you around!
            best luck with work !
              FWIW, if you look at the instructions for using Shape Bender you'll see that Chris said the curve should be on the red/green plane which yours isn't. The shape should then be oriented in a corresponding method. You'd probably find it works more easily if you actually drew the curve on the ground plane from the beginning.
              • gillesG Offline
                gilles
                I also notice that the location of the curve can give different results. ❓
                ShapeBenderVoodo_V6.skp
                • ely862meE Offline
                  ely862me
                  Wonderful ! Finally learned how to deal properly with it !
                  Shape bender.skp
                  • Chris FullmerC Offline
                    Wow, looks great!
                    All my Plugins I've written
                    • tibetT Offline
                      tibet
                      hi guys,
                      thanks for your samples, excellent results !
                      http://img.sceper.eu/images/U2Ydy.png
                        somebodyelsesmail
                        @chris fullmer said:
                        Wow, looks great!
                        so when i use shape bender i get the grid after pressing both the straight line and curved line but when i press enter it just moves my object randomly on the screen. It does not bend the object to the path.
                        Thoughts?
