    Thoughts on low poly trees
    2 Posts 2 Posters 359 Views 2 Watching
    • S
      sgbotsford
      AFAIK there is no locus command in sketchup.
      Eh?
      A locus is a set of points meeting a condition. E.g the locus of all points 6 inches from one point is a sphere 12 inches in diameter.
      Consider if you had a tool that could create a volume with a surface that was X units away from an object. Essentially it would be a 3d follow- me, but would work more like push pull.
      Now build a coarse main branch structure for a tree.
      One. Object is grouped. Locus is the envelope of the entire group.
      Two. Object is ungrouped. Locus is the set of the envelopes of each element.
      Now, consider if you apply a translucent shade to the surface, you end up with a watercolour of the tree.
      Workable?
      (Now someone will tell me that its been done, it's simple, and instructions are found. . . )
      • thomthomT
        Got some visual examples?
