    Triangulation and Convex Polygons
    25 Posts 7 Posters 2.1k Views 7 Watching
      mrapsouthern
      Using Sketchup 8 Basic. Windows 7.
      I need a plugin to first triangulate a face.
      Then I need to reduce those triangles into fewer irregular polygons.
      Does anyone know of one or two separate plugins that would do the job? I have a lot of these situations and I want to avoid drawing these convex polygons manually.
      The image shows an example starting point which is bad and an example of what would be interpreted correctly with the 3rd party software I'm using.
      Alex
      http://dl.dropbox.com/u/22511393/tmp.png
      • cottyC Offline
        cotty
        Have a look at split donut (works with your example, but maybe not in all cases?)
        my SketchUp gallery
          mrapsouthern
          I tried and it works with the simple example I gave.
          BUT for the following real case pictured, it does not.
          Does it work for you?
          Ultimately the problem is that the 3rd party software does not see a hole. The bounding rectangle fills the hole in. Hence why I need to split it up before export.
          Here is the SKP file:
          http://dl.dropbox.com/u/22511393/example.skp
          http://dl.dropbox.com/u/22511393/tmp2.png
            In the first example, that's not really triangulation though. There are triangulation plugins out there - that expose the underlying triangulation of SketchUp's faces. But I gather you just want to split up faces to avoid holes?
            What exporter do you use? (Since you mention you experience problems when transferring the model to other applications.)
              mrapsouthern
              I export using http://www.rahe-kraft.de/cms/su2catt/index.htm
              Just to be clear, I want the hole to be present.
              I could use a triangulation plugin, this does solve the problem in theory (and practice sometimes).
              However, for the acoustic software it is better to reduce the number of polygons and also to avoid skinny/narrow/spikey triangles.
              Alex
                quadrilateralizer by tig ?
                but normally your surface must be automatically triangulated 😲
                  That actually creates more faces than just normal triangulations.
                    Is there some consistency to the mesh? Writing a generic tool would be pretty much impossible as there are so many mutations. But if the holes are always square - then the task is more predictable.
                      Oh, right - you posted that curvy thingy...
                        I have drawn a flat form like your. No Made any split !
                        Export in OBJ format by Tig OBJ Exporter
                        No Problem ! I have hole and only triangles in Wings3D for example! πŸ˜„
                        I don't understand your little problem 😲
                          mrapsouthern
                          @Pilou Basically the exporter and 3rd party software I use cause the hole to be filled in. It looks like the OBJ exporter you used exported the underlying triangles defined by Sketchup.
                          I can achieve the same by using a triangulation plugin prior to export.
                          That is as far as I have got. As you have also shown, it works, but the issue is that the triangles are very skinny/narrow/spikey (however you want to describe them).
                          I think this is as good as it can be, but the skinny triangles are not desirable. The only way to avoid them that I can see is to approximate the hole with fewr polygons, at it is the curves that cause the thin triangles.
                          Thanks for your help. Further suggestions are welcome though.
                          Cheers
                          Alex
                            what if... for each face with a hole in it one edge is drawn from the inner loop to the outer loop? (Even here there are cases where it could be difficult to do by script - for instance if there are multiple holes in the face.)
                              mrapsouthern
                              Got a solution in theory...
                              What I need is a plugin that will allow me to select a face with one (or multiple) holes in it and then divide that face in some way so that there would be multiple faces without holes.
                              i.e. for each hole in a face you only need to add two lines to split the face with 1 hole into 2 faces without holes.
                              Similarly,
                              a face with 2 holes requires 4 dividing lines and results in 3 faces with no holes.
                              a face with 3 holes requires 6 dividing lines and results in 4 faces with no holes.
                              a face with 4 holes requires 8 dividing lines and results in 5 faces with no holes.
                              This solution would mean you can represent a complex geometry with holes without splitting the whole model into triangles.
                              Is there anything already out there?
                              Alex
                                MattC
                                Thomthom's idea should work great in case there is only one hole in a face, and if You make more vertices on the outside loop. The problem with 'spiky' triangles is that You have only 4 vertices to which the edges are drawn.
                                Assume that You have two sets of points:
                                [inner_vertices]
                                [outer_vertices] - for example 25 points per rectangle side
                                For every point from [inner_vertices] find closest point from [outer_vertices] and draw an edge between those two.
                                (Possible problem) when two outer points have the same distance to inner point. Which point to choose ?
                                Cheers
                                Matt
                                  Can you post an image with result wished ?
                                    I was thinking one edge from inner to outer was enough - in order to reduce the number of faces.
                                    But thinking of it more, ultimately everything breaks down to triangles, so if you have a polygonal face in SU - internally it'll be made up of many triangles. The same thing goes for any other software. So converting a face into it's internal triangles doesn't really make the model heavier - in terms of total number of triangles the graphic card needs to draw.
                                      Better to make a retoplogy in 3D party ?
                                        mrapsouthern
                                        To update my previous post -
                                        Any 1 face with ANY number of holes can be divided into 2 faces with no holes.
                                        where the number of required dividing lines is defined by,
                                        NumDividingLines = NumHoles + 1
                                        please see the following diagram as illustration.
                                        http://dl.dropbox.com/u/22511393/tmp3.png
                                        Alex
                                        • gullfoG Offline
                                          gullfo
                                          slightly off-topic:
                                          http://gamma.cs.unc.edu/propagation/main.pdf
                                          http://sketchucation.com/forums/viewtopic.php?t=36063
                                          Glenn
                                          http://www.runnel.com
                                            mrapsouthern
                                            @gullfo said:
                                            slightly off-topic:
                                            It is off topic - but I am very familiar with that work - it's quite a coincidence you posted it....
                                            • 1 / 2
